s2000 knob on CLS
Old Mar 31, 2005 | 09:08 AM
rcz22's Avatar
s2000 knob on CLS
Bought the OEM S2000 knob, and its never really been that tight. When i hand tighten it as far as it will go, I'm looking at the shift pattern vertically with 1st gear at the bottom....
basically it needs like 1/4-1/3 turn to be perfect, but since I can't tighten it anymore, I turn it the other way so it stays loose but at least the shift pattern is horizontal....
anyone else have this problem? and how did you go about fixing it?
thx
Old Mar 31, 2005 | 09:18 AM
Smitty's Avatar
get the same size nut.... screw the nut on first... then the shift knob to where you want it... then loosen the nut towards the shift knob... that will fix it.
if it still moves... take it all apart and use some loc-tite.
Old Mar 31, 2005 | 09:19 AM
rcz22's Avatar
great idea, thankx
Old Mar 31, 2005 | 09:20 AM
Slimey's Avatar
Where is my super sauce?
You can stick a washer or other spacer on top of the shifter post to adjust. Once you find the right spot you can use some blue (weak) thread lock glue to hold it in place. I'd problaby use only a small drop of the stuff so you can break the grip later on if you need too.
Old Mar 31, 2005 | 09:21 AM
Slimey's Avatar
Looks like Smitty beat me to it!
Old Mar 31, 2005 | 10:13 AM
123456SPEED's Avatar
CLS 6MT Navi
Pic? Can't remember, Is this knob like the TSX? I have the TSX knob that has the red shift pattern on it. just need a screw washer on there first to screw against...so to speak.
ps- I fixed the boot already.
Old Mar 31, 2005 | 10:29 AM
rcz22's Avatar
yeah thats the one...the s2000 knob is exactly the same only the lettering is in black.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Popee
Dec 20, 2015 12:08 AM
Oakroadsteve
Oct 28, 2015 10:28 PM
Hines57
Sep 24, 2015 01:58 PM
