RVM Racing Crank Pulley
Old Apr 14, 2003 | 11:48 PM
liquid_x's Avatar
I was browsing through my newest super street and I came across this ad for pulleys and I noticed an application for our car. I searched online and I came up with this. What do you guys think? Doesnt it seem too cheap because isnt the UR one in the 200s?
http://www.rvmracing.com/product.asp?0=273&1=312&3=309
Old Apr 14, 2003 | 11:58 PM
mattg's Avatar
UR is probably just overcharging because they can.
think about it, $200 + for a piece of aluminum
i'm sure that makes for a good profit margin.
Old Apr 15, 2003 | 12:03 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Just read the descrpition...seems they do not know what oversize from underdriven... Actually, you need the Crank Pulley smaller NOT bigger to underdrive the other pulleyes. Anyways, the UR crank pulley has more holes than this one.
I had the UR pulley for like a year and no problem.
Old Apr 15, 2003 | 12:06 AM
mattg's Avatar
Originally posted by Nashua_Night_Hawk
...seems they do not know what oversize from underdriven... Actually, you need the Crank Pulley smaller NOT bigger to underdrive the other pulleyes. .
you sure about that? :sqnteek:
Old Apr 15, 2003 | 12:07 AM
Happy CL-S Pilot
YES!
Old Apr 15, 2003 | 12:26 AM
mattg's Avatar
so, you're telling me a smaller diameter crank pulley won't make the acces. pullies spin faster?
think about it.
Old Apr 15, 2003 | 01:02 AM
Happy CL-S Pilot
mattag:
I am 100% sure the UR crank pulleys should be SMALLER not bigger to underdriver the accessories pulleys:
Read here:
Lightened Underdrive Pulleys
1) "What are Unorthodox Racing lightened underdrive pulleys?"
Unorthodox Racing lightened underdrive pulleys come in four versions. The first version is our Ultra S, which is the lightened underdrive crank pulley. It drives all the accessories that came factory with the car. The Ultra S lightened underdrive crank pulley is smaller in diameter and 60-90% lighter than the OEM crank pulley it replaces. All of the underdriving is done from the Ultra S lightened underdrive crank pulley.
The second version is the Ultra R lightened underdrive crank pulley, which is also a crank pulley. It drives only the alternator or alternator and water pump depending on the application. It was developed for the racer and for engine swaps. It has the same percentage of underdriving as the Ultra S version but is 90-95% lighter than the OEM crank pulley it replaces.
The third version is the Ultra SS lightened underdrive pulley set. The Ultra SS lightened underdrive pulley kit comes with the Ultra S crank pulley and our Ultra A accessory pulleys for the alternator, power steering, and water pump (depending on your application). The Ultra SS lightened underdrive pulley kit has no more underdrive than the Ultra S lightened underdrive crank pulley, meaning you will have no electrical, cooling, or power steering problems. The a/c is still driven from the crank pulley in the Ultra SS kits so don’t think it has to be removed or can’t be used.
The fourth version is the Ultra A accessory pulleys. The Ultra A accessory pulleys are what make up our Ultra SS kits, but more importantly they are available individually for owners who have already purchased our Ultra S lightened underdrive crank pulley and now want the Ultra A accessory pulleys to finish their pulley set.
Unorthodox Racing lightened pulleys underdrive the accessories by changing the diameter of the crank/eccentric shaft (main) pulley. We underdrive the accessories with the Ultra S crank pulley in order to maximize the weight loss versus the OEM crank pulley. Underdriving also allows us to reduce the drain of each of the accessories off the crankshaft.
2) "How do Unorthodox Racing pulleys give me more power?"
Weight loss is the most critical factor in HP production, each lb. of mass taken off the crank/eccentric shaft is worth approximately 2.7 HP and the figure increases with forced induction, nitrous, VTEC and increased RPM's. Only 15-20% of the gains seen from our pulleys comes from the underdriving. We achieve the maximum gain for each application/model by the singular use or combination of reduced diameter ("underdriving") and weight loss versus the OEM crank pulley/s. This principle allows us to maximize the HP gain without causing any adverse effects in the general function of the vehicle.
The diameter of each of our crank pulleys is reduced specifically (from 20-30%) to the vehicles accessory needs. In other words we maintain all accessory minimums: air conditioning efficiency, power steering feel, and voltage (minimum allowable voltage 12v) even at idle with everything electrical on in the car. There are no adverse effects from the use of our pulleys whether Ultra S, Ultra R, or Ultra SS pulley sets are used. Bolt them on and forget about them, then just follow your vehicles normal maintenance schedule.
Old Apr 15, 2003 | 01:08 AM
Titand19's Avatar
East Coast Boost.!
UR is charging more for the same reason Comptech is. R&D. That place is right near me and they prob just used the UR design.
Old Apr 15, 2003 | 02:00 AM
DaveTypeS02's Avatar
is it worth it to get pulleys? im thinking about gettin em
Old Apr 15, 2003 | 02:07 AM
Titand19's Avatar
East Coast Boost.!
Get them.
Old Apr 15, 2003 | 02:28 AM
PiMpiN wHITe Cl-S's Avatar
is it a reputable company??..never heard about them..im thinking of getting them too..but then still thinking
Old Apr 15, 2003 | 08:32 AM
Samer007's Avatar
Smack My B*tch Up
Those are 1.8 lbs , what was the UR ?
Old Apr 15, 2003 | 10:49 AM
allmotor_2000's Avatar
I like UR. About 6 years ago when they were starting as a company, they sent me a free pulley for my Civic drag-car... worked very well. Since then their products have obviously improved.... and is viable in this performance-driven market.
Old Apr 15, 2003 | 01:01 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
I don't believe in the crank pulley, but if you do want one...pay the extra $20-40 and get a company that has tested it. I mean your hoping UR understands that a certain amount of weight is still necessary for the crank pulley. Whereas maybe these guys copied their designs...and just got a company in Taiwan or the PIs to copy it, ie no quality control.
Old Apr 15, 2003 | 10:51 PM
flint's Avatar
I am thinking about the UR pullies as well. Anyone know where to find the new belts that are needed? i assume UR will say which size to get.
Old Apr 16, 2003 | 04:58 AM
mattg's Avatar
the part #'s for the belts come w/ the kit.
the UR pullies must be part of the reason i've been able to run 14.1's.
they do make the car idle a little rougher, but they also make it faster.
Old Apr 16, 2003 | 07:52 AM
typeR's Avatar
rougher? mine idled smoother than ever...i've been harping on this but there's a TSB on our motor mounts...and when i had mine bad there was a resonance at idle the rear mount had the rubber top completly tourn away from the body of it
acuratl26
Apr 23, 2020 07:30 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
