Rust Spots
Old Nov 7, 2009 | 04:28 PM
zac's Avatar
zac
Rust Spots
I need advice. Ive got 3 tiny chips, 2 on my fender and 1 on my door. They are starting to rust. I dont want it to get too bad, what can I do or where can I go to stop the rust/get it touched up.
Old Nov 7, 2009 | 05:15 PM
2Fast4you's Avatar
scrape out the rust till you see the bare metal and put touch up paint over it
Old Nov 7, 2009 | 05:43 PM
friesm2000's Avatar
B A N N E D
you can buy touch up paint at the dealer, or you might be able to find some at a parts store
Old Nov 7, 2009 | 06:29 PM
zac's Avatar
zac
Will it blend in with the paint?
Old Nov 7, 2009 | 06:44 PM
friesm2000's Avatar
B A N N E D
not prefect, but it's better then rust spots especially if they were to start to bleed (rust runs)
if you want it to match prefect, then i would say get a body shop to repaint the whole side then
Old Nov 9, 2009 | 03:46 AM
YeuEmMaiMai's Avatar
I paid $300 to get the ones on my roof removed. Perfect job
Old Nov 9, 2009 | 07:05 AM
zac's Avatar
zac
Where did you get it done? Did they just paint the area around the chips or did they repaint a larger area to blend
Old Nov 10, 2009 | 05:41 PM
dave586270's Avatar
Chamorro
Something like they they probably blended in. Its prolly a lil more to repaint the entire roof. The touch-up paint will def help and prevent further rust. I thought i had the same problem a month ago and it just turned out to be small contaminant stuck in the clear coat. Clay bar took care of that! Good luck with the repair.
Old Nov 10, 2009 | 06:21 PM
they blended in and re clear coated the roof. normally it would have been closer to $400 but I had them fix it at the same time they did the bumper (insurance claim) so they removed the cost of paint and mix labor. Luther Collision in brooklyn park mn. It will cost $1600 to fix the rest of the rust in the rear wheel wells and chips on the hood.
ITSJESTER
17
Dec 6, 2018 02:29 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
polish_pat
Sep 30, 2015 12:22 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
