Rough idle and take off
Old Jun 23, 2015 | 07:54 AM
Brandon Allen's Avatar
2003 Acura CL-S6
So just purchased another CLs6 since I wrecked my old one
I noticed it was idling rough so I figured with 94k miles it had to be the spark plugs. I replaced the plugs and the car idles a lot smoother now. Although, when I start to take off the motor shakes and runs rough. Seems like I'm not getting much power. I checked the coils and they all seem to be working. No CEL and no codes. I'm stumped...
My next idea was to clean the EGR ports and see if that helps.
Any help is much appreciated!
Old Jun 23, 2015 | 08:15 AM
clean egr and iavc
check motor mounts for movement
Old Jun 24, 2015 | 08:17 AM
2003 Acura CL-S6
Ok I about to clean the EGR. It's almost sounds like I have a really bad valve tick. The valves are soooo loud
Old Jun 24, 2015 | 08:30 AM
Valve adjustment
Old Jun 24, 2015 | 11:54 PM
01acls's Avatar
Check the compression.
Old Jun 25, 2015 | 04:15 PM
ExcelerateRep's Avatar
Former Sponsor
Definitely do a valve adjustment, check compression, and make sure you are getting spark.
Old Jun 27, 2015 | 01:15 AM
2003 Acura CL-S6
Ok thank you guys. I finally have a day off work tomorrow so I'll be cleaning our my EGR ports and doing a compression test. If that doesn't work I'll checking into getting a valve adjustment done.
I'll update asap
Old Jul 6, 2015 | 09:14 AM
robsTLtype-s's Avatar
robstltype-s
any word?
baelim
May 10, 2018 09:53 AM
DerrickW
Nov 15, 2015 05:52 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
ceb
ILX
Sep 27, 2015 10:56 AM
