rotora rotors on ACP.com
Dromaeosaurs/Velociraptor
damn dealership wanted $480 to resurface my rotors. Welp, that just tells me to get new ones now since that would have been my second time doing it and I would just need to replace them shortly afterwards anyways.
I saw the Rotora Slotted rotors on ACP. com and both the front and rears for a pretty good price. (not sure what other prices are out there, so they seem cheap to me)
Is that just a simple replacement or do I have to do other upgrades or whatever?
http://www.autocarparts.com/part/1234/2/
Originally posted by dgracer
That link is for the rears, the front are 172.00. You can also get Brembo blanks (not slotted or drilled) from tirerack.com for $100 for the front pair.
Originally posted by CLUofI
i would suggest also getting new pads with the new rotors, but you would have to.
lover and fighter
Yes, Raptor. Rotors and pads are all that is needed. Keep in mind that this new set-up really won't improve stopping distances much, if at all, but brake fade should be reduced over OEM.
I put these on my car,, direct replacement rotors and pads on front,, pads only on back,, I didn't turn the back rotors and everything fit fine,, I did notice stopping power did increase and the brake dust is a lot more than stock,, if this helps you ???,,
cool...thanks guys...this helps...just I cant stand the vibrations and the jerking feel during a regular stop due to the jacked up rotors....
ordering them now with new pads.
registered pw
Re: rotora rotors on ACP.com
that pisses me off when they give you outrageous #'s like that. i was quoted i think 140 for the fronts, but they did it under the tsb anyway
Originally posted by 3.2cl-s
just make sure when you get new pads to get Organic pads and not metal pads........as i had made this mistake and my rotors are already warped.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
