Rotora installed...smoking!?!
Old Aug 13, 2005 | 01:17 PM
skim's Avatar
just got my rotora slotted fronts /w ebc greenstuff pads installed... did the 5 60mph-10mph stops..cooled.. etc break in period... got home and i see smoke coming out of the brakes!! wtf.. is this normal??? any help please.. hope i didnt just fry my new brakes...
Old Aug 13, 2005 | 02:23 PM
turbowonder's Avatar
well sometimes when u get new rotors they will have them coated with a type of grease so while they are in shipment they are protected. You are suppose to wipe that grease off before u install them, if not u prolly will get smoke. Its a possiblity but im not 100%
Old Aug 13, 2005 | 03:02 PM
Smitty's Avatar
I am sure you touched them to install them.... it is normal.
JUST DO NOT WASH BRAKE ROTORS after braking hard, you will warp them instantly.. you need to let them cool..... if it rains and you are driving the car it will not hurt them since the rotor is turning and the brakes are constantly touching the rotor.
Old Aug 15, 2005 | 02:57 PM
AuCLSman's Avatar
the problem is the caliper. the caliper slides need to be thouroughly cleaned and re lubed with silicone grease. repack the slides and reattach the rubber boots. if this isnt done properly, the outer shoe with hang up on the new rotor and over heat and eventually cause rotor warpage.
after this process test. and listen for slight noise while modulating the brakes , driving slowly. if you still hear slight hissing/grinding noise, replace defective caliper
Excelerate
Sponsored Sales & Group Buys
186
Mar 2, 2017 04:36 AM
Excelerate
664
Aug 4, 2011 09:22 AM
Smitty
Nov 9, 2005 06:28 PM
Excelerate
Jul 2, 2004 11:46 AM
