Do these prices sound right?
Old Aug 12, 2005 | 04:49 PM
juruki's Avatar
I called the dealer for an estimate for ballast (inverter) installation and they quoted me 180 for the right side? It sounds kinda pricey. I also asked for the price to resurface my rotors and they told me it was gonna be 280?
Funny thing is, I asked if warped rotors were a common problem on our cars and the service representative was making up some bs about driving conditions....
Old Aug 12, 2005 | 04:57 PM
spicyhands's Avatar
yeah those prices sound a lil crazy
Discount Auto resurface's rotors for $20 or so
Old Aug 13, 2005 | 10:37 AM
phipark's Avatar
Not Asian
You might as well buy new rotors for that price.
Old Aug 13, 2005 | 11:35 AM
Lord Helmet's Avatar
I'm here in spirit...
Do you already have the inverter or are you buying it from them too? They told me this morning (see thread https://acurazine.com/forums/showthread.php?t=172564 ) that the front bumper cover had to be removed. Seems pretty involved to me but then again, I've never taken my bumper off. They quoted me around $500 for the inverter, bulb and installation before Acura said they'd cover it.
Old Aug 13, 2005 | 01:14 PM
civicking's Avatar
taking the bumper off takes about 10 minutes if you don't know what your doing i can do it in about 3-5 minues.
Old Aug 13, 2005 | 01:17 PM
juruki's Avatar
Is it that hard to replace the inverter? I was thinking about ordering them online and have them installed at the dealer (or do it myself if its not too hard).
Also i was gonna order from http://www.acuraautomotiveparts.org/ and it says qty required is 2? Does that mean I get 2 inverters for 330?
Old Aug 15, 2005 | 04:36 PM
juruki's Avatar
help me plz, i need to fix my headlights asap
Old Aug 15, 2005 | 04:52 PM
civicking's Avatar
steps:
1. make sure to have the radio code
2. turn the lights off
3. disconnect the battery
4. remove the front bumper
5. disconect all the electrical connectors form the head light
6. remove the 5 monthing bolts then remove the corner upper beam and head light assembly as one.
7. disconnect the connector from the inverter if you have not done so yet
8. remove the torx bolt using a tamper proof torx t25 bit from the cover that is hiding the bulb ( cover that says warning 25000 volts or something)
9. turn the cover 45degrees counterclockwise to remove it form the head light assembly
10. turn the electrical connector 45degrees counterclockwise to remove it form the bulb
11. on the bottom of the head light remove the 3 mounting screws holding on the inverter and pull it off along with the wire that goes to the bulb.
12. install reverse of removal.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
james357
Feb 13, 2016 02:37 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
