Rotor cost on the CLS?
Administrator Alumnus
For those of you that have had rotor issues... What does a NEW OEM rotor cost? Just the part, not with labor.
Thanks!
Thanks!
how much do good aftermarket rotors cost (all four) for the TL-S/CL-S? Cuz I'm taking my car in this wednesday for the second time (related to warped rotors) and I'm just thinking I'll buy new rotors if they're going to charge me this time...
The only reason I was asking is, because the rotors on my G are right at $500 a pop.
I figured CLS rotors would be cheaper, but I didn't figure by a factor of FOUR!
Sweet as Gold
rotors on the G could be more for many reasons...the abs toothed ring for the wheel sensor could be casted in into it...as well as the wheel hub and or bearing. Acura rotors are bare rotors...nothing else...my dealer sells them for $138.95 each.
Just call me DADDY!!!
http://www.acuraautomotiveparts.net/...catcgry4=KA5AT
u can search for it here.
$132 for front and is about the same for the rear too.
Masshole
1 Post
Originally posted by Bulldog01
I'll check what I paid when I get home, but I think it's closer to $120 than $65.
Keep in mind this is all for rears, so fronts could be more, I would guess.
Plain Brembo Rotors are $50/ea and pads are $69 per rear axle for GreenStuff $89 for for front axle set at TireRack.
http://www.tirerack.com/brakes/resul...=perf&x=25&y=7
Has anyone tried the $50 Brembo replacement rotors, This sounds to good to be true. how are they?
can anyone recommend pads, I'll try anything but oem again.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
