roadlamp/foglight disaster!!!!!
i'm trying to separate my lenses from the housing on my new roadlamps (BTW,thanks Greenmachine). I've searched the threads and found the baking in the oven at 300 degrees, but it didn't work. One dremel tool that has way too high rpm and a cracked housing later.....
does anyone suggest a certain time/higher temperature?
has anyone even attempted the roadlamps before, 'cause all I see is posts on headlamp separations.
oh no, that sucks
did you crack the front or rear? (You said housing ... I'm assuming rear.
I would have clamped it down and would have using a small drill bit to cut the rear of the housing out. A dremel vibrates to much, which probably cracked the housing.
Sorry to hear that.
Sorry to hear that.
don't try heat gun lol i ended up melting the lens before even melting the sealant. I think the sealant dry hard as glue so theres no way to soften it..... i have one extra cracked foglamp so if you guys think of something to do to remove it, i'll experiment it for you before you ruin yours....
i'm trying to paint them to match my '03 headlight housings-but i don't think it's gonna work. I'll just mount the fogs in and be done with it. I had to order a new housing today from the local acura dealer for f-ing $56. my hella optilux projector fogs are coming in today so I should have pics of atleast one done tomorrow. I'll keep everyone posted.
HOWELLiNC
09-19-2015 12:12 AM
kansaiwalker1
11-30-2003 07:12 PM
