Rim and tire question
GOD Of ACURA-CL.COM
You guys think this is a good set up I'll be getting the Rh evolution C-2 ...they'll be here tommrow and i'm probably going with the toyo FZ-4 225/40/18 . The C-2 have an offset of +42 will this be ok ? Thanks
if its a 7" wide rim, yes it is equivilant to a 18x7.5 with a 48 offset.
if its 7.5, you can not lower without rolling fenders.
if you dont want to lower its no problem, and you may even be able to put a 235 tire on, which some may want.
It's Go-Time.
You should be fine. I had the same rims w/ H&R Sport with no rubbing. Makesure you get the wheel spacer too, without it, your rims will not clear the brake calipers.
How much did u pay for your setup and where did u get them at?
Type SSS
My cars not even lowered.
Type SSS
Re: Rim and tire question
IT WILL RUB FOR SURE.
GOD Of ACURA-CL.COM
Re: Re: Rim and tire question
GOD Of ACURA-CL.COM
Since you won't have a snow issue, why not go with the 3 season proxies?
GOD Of ACURA-CL.COM
Alright my rims have finally came in today . I still want to know since i have a 42 offset that if i lower it will it rub if i put spacers on it ? B/c this is gonna piss me off bad if it does They look soo sweet too
Yip, that's what I had to do... and I also had to bend the inside of the fender well lip upwards. I used a crescent wrench to do the bending, very gently, very slowly. I didn't want to bend the outside or crack the paint.
I also had to take a file to some metal right above the area I trimmed. (right above the arrow on his picture) Oh yeah, I used a dremmel to take off some of that plastic. I was able to make a perfectly smooth cutout and you'd never know I had to do it. Even used touch up paint on it.
As far as the brake caliper goes, it's no where close in the rear, but in the front, the brake caliper was literally less than a credit card's width from the back of the wheel. But it didn't rub and I don't have any problems.
The brake pads were 30% worn when I put the wheels on, and I'm afraid when I put new pads on the caliper might get in the way.
It's Go-Time.
It's Go-Time.
Originally posted by mcdanjw
GOT PSI?
Where did you get the spacers? How much?
GOT PSI?
GOD Of ACURA-CL.COM
You are right, the front calipers were too close so the shop I purchased my RH C2's from supplied a THIN spacer to clear the calipers a bit more at no charge.
It's Go-Time.
So basically I'll be straight as long as i get a thin spacer for the front...right ? SO i'm guessing i dont have to cut bend or do anything to my fenders too ...right
nuldabz
09-03-2015 05:49 PM
