Resetting VSA and other lights....
Old Jul 30, 2003 | 05:21 AM
GD196's Avatar
A while back I got hit and my VSA lights kept staying on after that...Now I know i have to goto the dealership but they are charging $85.00 is there anyway I can do this myself? And will it mess up my car in anyway for not resetting it ASAP?
Thanks!
Old Jul 30, 2003 | 06:37 AM
CO-CL-S's Avatar
It's my understanding that VSA comes on at the time VSA is going active (one or more wheels spinning?)? If it remains on then there may be a problem with your VSA system? I guess I'm confused..
Old Jul 30, 2003 | 06:40 AM
blk_coupe's Avatar
Actually I would give it a couple of days. After my Inspect/Emission test my vsa light remain on for a day or two.
Old Jul 30, 2003 | 06:45 AM
JaySyn77's Avatar
GD: Have to tried to disconnect your battery and then see if it still turns on?
Old Jul 30, 2003 | 08:24 AM
sidemarker's Avatar
Re: Resetting VSA and other lights....
Thanks!
are you not under warranty???
sidemarker
Old Jul 30, 2003 | 08:06 PM
GD196's Avatar
I am under warranty...I had a little hit so i guess the lights just stayed on after that....The car drives fine i just need to get these lights reset its annoying!
Old Jul 31, 2003 | 05:08 AM
CO-CL-S's Avatar
You mean a little hit, as in one or more of the sensors got "wacked" and that's why the VSA is on? Sounds like maybe you should get it fixed? I hope you are driving with the VSA turned off, or you could be applying brakes, etc. for no reason. YMMV
Old Jul 31, 2003 | 07:11 AM
sundance_gold's Avatar
If you're under warranty it should be fixed under warranty--unless there is more to the story than what's here.
Old Aug 1, 2007 | 01:46 PM
LECKEY73's Avatar
Ok. So can somebody answer the question? how do you reset the vsa with out a scan tool?
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
polish_pat
Sep 30, 2015 12:22 PM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
