Removing headlight housing
Whats up with RDX owners?
Heat. Melt the glue then pry it apart.
wham bam thank you ma'am
stick in oven for about 15min at 225-250 degrees F. get some thick gloves (not the rubber ones) and pry the tabs loose then pry the whole thing open. its a lot easier with two ppl. one holds and cleans the glue and the other one prys them open.
do what u need to do, then put both pieces together and try to lock the tabs, then put back in oven for about 5-10 min at the same temp as before. when u take them out of the oven, press them firmly together for a few minuets so the adhesive can cool down and stick, recheck the tabs to make sure its all tight.
and hope for no leaks.
Chamorro
Yeah everyone likes to use the oven. I wasn't too fond of the idea so i used a heat gun. Same premise, but a little more control. I used one when i clared my headlights:
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/d-i-y-clearing-headlights-495390/
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
