Removing Emblems disaster
I tried to remove the emblems from the trunk. First I removed them with floss then tried to remove the glue with Goo-Gone and that's where i'm at. I made the biggest mistake of using a blade now it's all scatched . There is still glue on the trunk that feels like cement and it won't come off. I've used a hair blow dryer,goo-gone and bug and tar remover, nothing has worked.
Any Suggestions on how to remove the left over glue and the scratches is helpful
Thanks in Advance.
Thanks in Advance.
I scratched the hell out of my car the first time I debadged...on my 97 jetta..... Don't worry I debadged about a week ago got most of the glue off but I have a ring of like super glue stuff around each letter.....I even took the acura symbol off and now I have two white rings or holes.....I think I am gonna go to the body shop and see if I can get them to wet sand and repaint the whole thing hopefully around 300-400 dollars if not I am gonna stick all that shit right back on........good luck though........have fun at the body shop though...you will look clean when all said and done though
CL-S retired 10.17.06
bad move using a blade. I didn't have goo gone when I debadged so I had sore thumbnails. I ended up using carb cleaner and it came off easily. Washed the car and waxed to get rid of any residue.
I'm here in spirit...
Isn't it just double-sticky tape??? I worked at a body shop and used to pull them off all the time. (not my car though, i like 'em.. at least on the CL-S.. I used to, BEFORE ANYTHING... heat the emblems first with a heat gun (not a blow dryer, not hot enough) but you have to becarefull not to get the paint to hot or you'll pull it off too. Just get them hot enough that if you pull on it with your fingernail or something really thin and sturdy (NO METAL, you'll F*** it all up), it will move outward a bit. At that point, you should be able to keep a firm tug on it and pull right off..SLOWLY! (NO METAL, you'll F*** it all up). The left-over residue shouldn't be too significant if you kept it pretty warm durring this process. That residue can be removed by rubbing firmly on it with the tip of your thumb. Got a little line around the emblem left?? A light cutting rubbing compound then a couple coats of wax should take care of the rest. I'd try to stay away from all those harsh chemicals. Bad for the finish, esp ther ones with silicone i them. I hope this helps fellas!
i had the same problem (without the blade of course). i ended up getting adhesive remover from advance auto parts (expensive goo gone). the trick is to let it soak in (can't find the post where they told ME that). i used napkins and masking tape. make a |_| shaped pocket around each letter and then tilt the bottle to pour some on. let it sit for about five minutes and then scrub with a soft cloth. for the last little bits i ended up using a screwdriver covered with two layers of towel and that seemed to do the trick.
of course, now i have the ghost images of all the letters ... looks kind of cool but a good wax will fix that i hope.
good luck
good luck
Adventurist.
Originally Posted by DOO
what possible reason could you have for removing emblems? Did you wake up and say, "Oh, I will remove my emblems today?"
GEEZER
GEEZER
:troutslap
cl-s o1 from il
hello thank you all you guys cuz this site rocks and about the emblem removed i did mine with the blow dryer and some polish remover (for nails) what i did is that i put the blow dryer in low and as soon starts heating with the blade gently remove it one by one of course the take will stay in there but no worries just remove it and when you finish just with the polish remover start taking the glue out it takes some time but no harm to the paint at all and with a good paint polish and thats it like i didn't exist. hope this little tip of mine help you guys
B A N N E D
hmmm mine was super easy.. hair driver, dental floss and 3M adhesive remover.. along with some elbow grease...
p.s. i totally dig how the type-S is on the bottom corner on that pciter that guy sposted.. anymore pics type-s boi?>
Originally Posted by gaping46and2
Not sure acetone would be too nice for your paint, I'd suggest layering a couple more coats of wax over your trunk just in case.
I still think I had the best method.....Get rear ended, don't replace badges.
Who did this in
bye Acura, hello Toyota
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
dainmezron
10-16-2015 06:56 PM
