Remote starter. Need Wiring Help
Help!
I'm getting my butt kicked pretty good right now. I am installing a remote starter that integrates with the OEM alarm and keyless entry.
I'm having a hell of a time locating the door lock wire. Every wiring diagram I've seen says it's a black/blue wire in a light green 20-pin connector located in the passenger fuse panel. This wire is supposed to send a negative pulse to activate the remote starter.
Everything else is hooked up and working fine. I know this because when I touch the wire from the remote starter that is suppose to connect to the door lock wire to ground the car starts.
Does anyone know exactly where I can find this wire?
SUPRMN84
10-07-2015 09:46 PM
