Remote Start
Old Nov 1, 2007 | 09:03 AM
02CLNOS's Avatar
Talking Remote Start
I was just wondering if anybody has a Remote Start on their cl-p auto, cl-s auto, or their cl-s manual? I am thinking about getting it done in the near future but i haven't seen or herd about it on out cars, what systems are the best or what do you have on yours?
Thanks Scott
Old Nov 1, 2007 | 10:25 AM
01clsstock's Avatar
i am so smart S M R T
Thumbs up
i have a remote starter on my auto 01 cls. Its great for winter, unless its really cold than it doesnt work ( car wont turn over) Not sure what kind it is because it was on the car when i bought it.
Old Nov 1, 2007 | 11:47 AM
fuzzy02CLS's Avatar
I had a Viper 550ESP on my old 02 CLS. Worked fine.
Only issue with any aftermarket alarm on the CL/TL is you have to ground out the factory alarm. Or else it may go off unexpectedly. Simply hooking up the factory disarm wire does not do it. The wire is a blue wire that goes into the drivers door, & into that little flashing security light.
Old Nov 1, 2007 | 12:30 PM
CL-Future's Avatar
Lives in Boost
I've got a Compustart Remote Start on my CLS6. Good point about grounding out the factory. I dont think the place that installed mine did that cuz it goes off if I autostart the car before disabling the alarm. It's not bad though. I unlock it, autostart it and then lock it while it's running. All are still done remotely so it doesn't hurt.
Old Nov 1, 2007 | 11:37 PM
m733l's Avatar
i have the viper 550esp on mine as well. it's a manual and installed since i bought the black bueaty since april2002. no problems to date.
Old Nov 2, 2007 | 01:44 AM
E-MONEY's Avatar
SleepinCLS
I have the clifford alarm, and its not something i recommend. Till this day i don't even know how many times i used it. U may come across electrical problems. Also alarm goin off for no reason or if u switch remotes.
Old Nov 2, 2007 | 08:37 AM
datzdaboi's Avatar
B A N N E D
I have a Clifford remote start on my car no problems whatsoever
Old Nov 2, 2007 | 08:45 AM
fuzzy02CLS's Avatar
Ground out the factory alarm & I'd bet you won't have a problem. And may have been a crap installer.
Old Nov 2, 2007 | 10:42 AM
m733l's Avatar
clifford and viper is both from DEI. and viper is there superior line...at least that was the case couple years ago when i use to install these puppies.
Old Nov 3, 2007 | 04:52 PM
02CLNOS's Avatar
what did it run you for the instal=alarm? I want to go with the viper!
Old Nov 3, 2007 | 06:19 PM
bobpez's Avatar
You can program the alarm to unlock the doors then start the car and then relock them by itself. That is how I had it set up when I had a Legend. I would probally just ground out the factory alarm to save the hassle if I put one on my CLS. I have had many DEI remote start setups and have had no problems.
Old Nov 4, 2007 | 01:01 AM
MinTS's Avatar
ok, maybe i missed it. but did someone mention they had a remote start on their Manual....I wanted to make sure i wasn't reading into it
Old Nov 4, 2007 | 03:25 AM
m733l's Avatar
sure did.
Old Nov 4, 2007 | 08:35 PM
fuzzy02CLS's Avatar
There are a few out there that have the safety features built in for manuals. IMHO I would only install 1 of these & not let any shop "rig" a system to work.
Old Nov 4, 2007 | 08:39 PM
MADMAN187's Avatar
How much do theese systems go for?
Old Nov 4, 2007 | 11:09 PM
Mikey415's Avatar
01 acura cl
I had a generic one installed for like 400, a long long time ago, but i spilled jumba juice on it (dont ask) and went back to the stock key fob.
Its pretty neat to have, all my friends would get annoyed because I would show off, and use it every time
Old Nov 6, 2007 | 12:07 AM
260TYPESNY's Avatar
I have a MARS system and it work great. I have both factory and aftermarket remotes. use them both and when i start my car it stays locked until i unlock it however i can only unlock it with the starter remote not the factory one.... works great i would reccomend
Old Nov 6, 2007 | 03:08 AM
m733l's Avatar
why do you need both remotes?
Old Nov 6, 2007 | 07:52 PM
260TYPESNY's Avatar
i just got both so i use them. the starter makes a honking when u start it so i use the factory one at night so i dont wake ppl up at night in my naighberhood.
Old Nov 7, 2007 | 10:35 AM
PMGCamaro's Avatar
Is there any way to configure the remote start system to work off of the Acura FOB... say by pressing the panic button?
Old Nov 7, 2007 | 10:58 AM
fuzzy02CLS's Avatar
Ground out the factory alarm & you won't have this problem. You only need the 1 RS key fob. Do it yourself. It's not hard to take the door panel off.
Old Nov 7, 2007 | 10:59 AM
fuzzy02CLS's Avatar
No
Old Nov 7, 2007 | 11:05 AM
New Image's Avatar
B A N N E D
Autopage RF-1000 way to go
Old Nov 8, 2007 | 07:42 PM
MADMAN187's Avatar
Which ones come without a security system?
Old Nov 11, 2007 | 06:55 PM
AcuredCLS's Avatar
AcuredCLS
honestly a remote start is a remote start, its who installs it. I bought my CLS with the autostart and im glad it has it, started it the other day when it was about 36 degrees out and it started right up. My remote start system is Valet, which is jsut a branch company of Viper and Auto Command i believe. I woudl stay away from auto command my old car had it and it sucks. Plus if ur car is a manual its pointless to buy the remote start. i here stories of people doin it and leavin the car in gear it..itll tryn start hoppin..my neighbor put his maxima through the fence with a remote start on a manual
Old Nov 11, 2007 | 06:59 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
what do you mean by ground out ? just tap into that blue wire? my alarm goes off as well, i'd realllllllllllllllly like to fix it!!!! thanks guys
Old Nov 12, 2007 | 07:44 AM
fuzzy02CLS's Avatar
unhook or cut the blue wire & screw it to a ground source. Like a metal body panel.
Old Nov 13, 2007 | 10:02 AM
Luca1014's Avatar
I installed my remote starter myself and I didn't ground the alarm out in the driver's door. Instead I disconnected the hoodpin and used a piece of wire to connect the two pins on the harness. This also causes the factory alarm to be disarmed and I thought it was much easier then taking the door off. Took less then 10 minutes to do. Also, FYI remote starts for manuals have safety features that will not allow the car to start if it is in gear (if the remote start is installed properly by an installer that knows what they are doing).
Old Nov 13, 2007 | 10:07 AM
fuzzy02CLS's Avatar
But then doesn't that defeat the hood pin switch? So if someone pops the hood the alarm will not go off even with the aftermarket.
Takes less time to take the door panel off. Once you do it once it's not a big deal.
Old Nov 14, 2007 | 09:31 AM
Luca1014's Avatar
Most alarms have shock sensors thats are sensitive enough to detect someone opening your hood. Granted it doesn't work as well as a hood pin switch itself but it does the job.
Old Nov 14, 2007 | 08:28 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
does grounding it out defeat the OEM alarm ?
Old Nov 14, 2007 | 08:30 PM
fuzzy02CLS's Avatar
Yes, but your installing an aftermarket so you want it disabled.
The chip in the key is a different system & is not effected.
Old Nov 14, 2007 | 08:44 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
ok, so lets say:
i like to lock my doors after starting my car, but sometimes i forget and leave them locked and start the car (setting off the OEM alarm). would this also be disabled ??
Old Nov 15, 2007 | 07:44 AM
fuzzy02CLS's Avatar
Yes. On most cars this should not happen, but the CL/TL is different for some reason. Once you ground out the stock Blue wire the stock system will completely not work.
Old Nov 15, 2007 | 03:58 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
so it's not one of the wires that actually goes into the little light is it ? i took my door off and there's a white and a red/blue/silver dots wires going into the light
Old Nov 16, 2007 | 01:56 AM
m733l's Avatar
there should be a wire from the after market remote starter that will send a neg pulse when you try to remote start your car. if you tap that wire to the blue factory wire, it will disengage ur factory alarm far that split second only. keeping ur factory alarm fully functional. that's if you want to keep both. if ur remote starter does not come with that wire, i would recommend you buy one that does. most of them should since that what installers use to bypass the clutch on manuals.
Old Nov 16, 2007 | 07:40 AM
fuzzy02CLS's Avatar
That's how it should work.
However the CL/TL it doesn't work with for some reason.
Factory disarm will not completely disarm the factory alarm. This will cause problems with certain features of the stock & aftermarket alarm causing the factory to go off when it shouldn't.
Old Nov 16, 2007 | 07:42 AM
fuzzy02CLS's Avatar
I'll have to check the manual. I thought it was blue, but that was on an 02. Maybe the 03 color is different.
Old Nov 16, 2007 | 09:56 AM
m733l's Avatar
sometimes system will send neg pulses back and forth. put a diode in line which will allow charge to flow one way only and it should not randomly set off the factory alarm.
Old Nov 17, 2007 | 05:00 PM
Luca1014's Avatar
It's not that the alarm is randomly set off, what happens is if the car is remote started and the factory alarm is armed, it won't be disarmed. For some reason aftermarket alarms can't disarm the factory alarm even when the factory disarm wire is connected. The diode stops false alarms, which I don't think is the actual problem.
