Redline's Waterwetter. .
anyone use it? it's been out forever, i know, and is praised by many, it drops temperature by 10-15 degrees. .i can get em for about $12. .
for those that don't know and will ask questions
WaterWetter provides a substantial reduction in cooling system operating temperature. Just 12 oz. in a 16 quart system can reduce operating temperature as much as 30 degrees.
Red Line WaterWetter with Rust and Corrosion Inhibitor (liquid) is designed to provide improved metal wetting and excellent corrosion inhibition when added to plain water or a glycol coolant. The most poorly maintained system in an automobile is usually the cooling system. Proper cooling system maintenance is very critical for most engines which utilize more aluminum. Aluminum has a very high corrosion potential, even higher than zinc, which is very widely used as a sacrificial anode. The only property which enables aluminum to be used in a cooling system is that it will form protective films under proper conditions which will prevent the uncontrolled corrosive attack of acids or bases. Poor aluminum corrosion inhibition will cause the dissolution of aluminum at the heat rejection surfaces, weakening the cooling system walls and water pump casing and the head gasket mating surfaces. These corrosion products will then form deposits on the lower temperature surfaces such as in radiator tubes which have very poor heat transfer properties, causing a significant reduction in the cooling ability of the entire system. Red Line WaterWetter will provide the proper corrosion inhibition for all cooling system metals, including aluminum, cast iron, steel, copper, brass, and lead.
Red Line WaterWetter can reduce cooling system temperatures compared to glycol solutions and even plain water. Water has excellent heat transfer properties in its liquid state, but very high surface tension makes it difficult to release water vapor from the metal surface. Under heavy load conditions, much of the heat in the cylinder head is transferred by localized boiling at hot spots, even though the bulk of the cooling solution is below the boiling point. Red Lines unique WaterWetter reduces the surface tension of water by a factor of two, which means that much smaller vapor bubbles will be formed. Vapor bubbles on the metal surface create an insulating layer which impedes heat transfer. releasing these vapor bubbles from the metal surface can improve the heat transfer properties in this localized boiling region by as much as 15%.
Key Benefits
-Doubles the wetting ability of water
-Improves heat transfer
-Reduces cylinder head temperatures
-May allow more spark advance for increased torque
-Reduces rust, corrosion and electrolysis of all metals
-Provides long term corrosion protection
-Cleans and lubricates water pump seals
-Prevents foaming
-Reduces cavitation corrosion
-Complexes with hard water to reduce scale
'01 cl-s blk/blk :: comptech headers, comptech springs, comptech sway bars
![](http://www.acura-cl.com/ubb/wink.gif)
Key Benefits
-Prevents foaming
<font face="Verdana, Arial" size="2">Originally posted by so cal type s:
Key Benefits
-Prevents foaming
</font>
Key Benefits
-Prevents foaming
</font>
Example: I ask the dealer if they mind putting in Mobil 1, and they say they do it all of the time.
It will probably work wonders, but I haven't noticed any problem with the cooling system, but I haven't been to Death Valley when its 130F in this car (I have done that in the Bimmer -- and it could have used it...)
So, does your car overheat?
Are you trying to cut down on the current pull from the fans cutting in during stops and idling?
Or is there something I missed....
It's just that I have never seen the car overheat in traffic when its been 105 in the valley (last summer)...
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 10 coats of Zaino magic
I used two bottles of it in my other car when it was running hot last summer and didn't notice much of a change in temp. Ending up swapping out the radiator for a more efficient one, which fixed the problem. (My experience may not be typical due to the old radiator though.) It is compatible with coolants but they suggest straight water treated with WaterWetter for maximum cooling effect.
Eric, So Cal’s car is probably not overheating; he’s probably just looking for a way to have the engine run a little cooler since performance usually goes up a bit from the engine running a little richer. And there's less chance for fuel pre-ignition ("pinging") avoiding a reduction in spark timing.
Speaking of additional cooling, how about swapping out our 194 degree thermostats for a lower temp one (say, 180 degrees)? That worked well in my other car.
I've used this over the years.... Most benefit was in cast iron v8 Chevy applications. No intention to use it in the CLS.
2001 Silver 3.2CLS
Muds, Spoiler, Hardwire 8500, Polarg M-6 lamps, K&N filter #33-2178,
Comptech Headers, Sways, mufflers![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Planning: SSR 17X7.5 GT1 Wheels, Brembo Brakes.
2001 Silver 3.2CLS
<font face="Verdana, Arial" size="2">Originally posted by tinman:
Speaking of additional cooling, how about swapping out our 194 degree thermostats for a lower temp one (say, 180 degrees)? That worked well in my other car.</font>
You don't just add the stuff. You change the ratio of coolent to water. So normally you run a 50/50 mix. With WW you run say a 65/35 water/coolent mixture or something to that effect. That's how you it lowers temps.
Also WW is used by motorcycly racing teams and track days. The rationale being that WW does not leave a slick patch when it leaks out like coolant does. Rarely do people run with WW during day to day driving. WW is also more environmentally friendly I believe, although I am not certain. I do know it does not leave the residue behind like coolant does.
2001 CL Type S w/ NAV & Spoiler. San Marino Red/Parchment int.
20% tint rear, 30% tint rear sides. Purchased 2/28/01.
http://albums.photopoint.com/j/AlbumIndex?u=1584587&a=12058921
1999 Honda VFR800FI San Marino Red, TBR X-Metal Hi pipe with K&N Filter. Purchased 9/9/99.
Just curious:
Why do people find the need to quote the entire previous post when replying? It's annoying to scroll through that extra page of text.
-J
2001 CL-S Aegean Blue/black interior spoiler, wheel locks, no-navi
Stock for now.
-J
Stock for now.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
<font face="Verdana, Arial" size="2">Originally posted by JRock:
Just curious:
-J
</font>
Just curious:
-J
</font>
<font face="Verdana, Arial" size="2">Originally posted by CLpower:
hey so cal type S, you gonna come to the meet on saturday?</font>
<font face="Verdana, Arial" size="2">Originally posted by Closer:
You don't just add the stuff. You change the ratio of coolent to water. So normally you run a 50/50 mix. With WW you run say a 65/35 water/coolent mixture or something to that effect. That's how you it lowers temps.</font>
![](http://www.acura-cl.com/ubb/smile.gif)
http://www.redlineoil.com/redlineoil/wwti.htm
Ambidextrous Masturbator
hey playboy. i'll be there. .the only problem is i have problems with waking up in the morning. .
</font>
</font>
Sid Vicious
2001 CL Type S w/ NAV in Silver | Wheel Locks | Front Plate (Mounted in the Trunk) | Mobil 1 | Polarg M6 NEW! |
1992 Ford Ranger XLT in Silver | F-150 Springs | 3" Body Lift | K&N Filter | Flowmaster Exhaust
vpasla1
09-17-2016 07:24 PM
D-Rob
62
01-05-2016 11:44 AM
EvilVirus
12-10-2015 07:38 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
