Rear makes loud noises when going over bumps
Old 02-14-2002, 12:19 PM
But I just got here
Nitin's Avatar
I just noticed that whenever my car goes over speed bumps, the rear of the car makes some kind of weird noises, almost like there's some kind of problem with the springs. It's more like a loud squeaking noise. Has this happened to anyone else? And just to make sure, I popped open the trunk and pushed the rear up and down a few times and there's these really loud noises coming from underneath. I have Comptech sways but still have the factory springs.
Old 02-14-2002, 12:30 PM
hatemystocks's Avatar
Mine was making noises too when I first got it. Turns out the muffler hangers were in the wrong place, so the mufflers were rattling around every time I hit a bump. Check to see if that may be the problem.
If not, I have no clue....
Old 02-14-2002, 01:42 PM
But I just got here
Nitin's Avatar
Thanks for the tip on the mufflers. I've checked them though and they seem to be fine. But after searching through some old posts, I'm guessing it's a blown shock. I'll be taking it into the dealer tomorrow morning to get it checked out.
Old 02-14-2002, 01:58 PM
mffdvr's Avatar
Double check to make sure you don't have anything (or anybody) in your trunk. :P
Old 02-14-2002, 02:01 PM
mackdaddy's Avatar
Did you use lithium grease, or teflon tape on the Comptech sway install? If grease, that's you problem. You nee to use the teflon tape at the bushing mounting points. Should solve you issue.
Jim
wayneg's Avatar
Check the sway bar bushings- may need lubing.
Old 02-14-2002, 02:18 PM
But I just got here
Nitin's Avatar
Jim and Wayne, thanks a lot for the info. I used the grease when the Comptech sways were installed so hopefully that's the entire problem right there.
Old 02-14-2002, 02:34 PM
dpvistaz's Avatar
yeah the same noise came from the rear...whenever i go over a bump i hear some squeaking noise...i dont know what it is... maybe my spare tires flying around in the back? i do not know....
Old 02-14-2002, 04:48 PM
I love my CL-S
WiLd~CL~TYPS-@SS's Avatar
i have the exact same noise right after i installed my springs... lube it...it will reduce the noise..
Old 02-14-2002, 05:57 PM
Buckle Up
monkeymato's Avatar
I had the same problem. I dont have springs or anything in the CL. It ended up being lose tools in the truck from Acura.
Old 02-14-2002, 06:01 PM
typeR's Avatar
there's a reason comp switched from the grease to the tape...id say get as much lube in there as possible and do your test again...if the noise goes away..dont worrie about until it comes back...if it comes back switch to the teflon tape....
Old 02-14-2002, 06:47 PM
www.drippinwet.com
acura_service's Avatar
i had the a weird loose lumber noise from the rear, it turns out that the inner webbing on the rear exhaust rubber hangers were the cause, they were cut out and its fine - i think it might have been a tl bulliten
Old 02-14-2002, 08:41 PM
Fuct in the hed!
Nicky Pass's Avatar
My muffler hangers had to be replaced also. It was like a light knocking noise.
Old 02-14-2002, 09:05 PM
EricL's Avatar
It is rare, but some folks have had their sway bar links break and they will make a squeak/noise. Surprising that people don't notice the loss of the rear bar's action around corners and turns, but it's been reported...
BTW, I like typeR's suggestion about the Teflon tape (re grease) and I'm going to change to the tape in my sway bar bushings.
Old 02-14-2002, 11:42 PM
The Creator
soopa's Avatar
my rear end sounds like its going to fall off the car when i go over bumps.
dunno what it is... could be the mufflers.
it sounds very similar to what it would sound like if your trunk lid wasnt shut and it was bouncing up and down when goin over bumps.
i would take it into dealer but theyll just use the subs in my trunk or the coil-overs as a cop out
i hate my local dealer.
i dunno how to analyze this sound. so i dont know how to fix it. could be anything ??
i dont have sways.
what should i be looking for when checking the mufflers (i cant do this till warmer weather anyway... too f-in cold)
Old 02-15-2002, 11:41 AM
Soopa... I think thats definitely the mufflers...
Mine were hangers were in the wrong place so every time I went over a bump, it would rattle against the car...
I would get under there if I were you and shake the mufflers and see if they rattle against the car body....
BTW when I installed the comptech exhaust, it stopped...
Old 02-15-2002, 11:45 AM
Soopa...
all you really need to do is walk to the back end, push down the muffler about a half inch to an inch and release it if it goes BOIIINNGGG and knocks against the body of the car, thats your problem.
Check the rubber hangers underneath and see if you can re-locate them. Or get a comptech exhaust... hehe
Old 02-15-2002, 11:53 AM
Petrie2001's Avatar
If it squeaks, then it it probably the grease on the sway bars. I used to have this problem. Everytime I went over speed bump, it the squeak would annoy me so much! Then I got the grease replaced with teflon tape and the sound is gone. It's amazing how some stupid tape can make your car so much better to drive!
Hope this helps,
Peter.
Old 02-15-2002, 06:13 PM
www.drippinwet.com
grab the muffler by the tailpipe and shake up and down if you hear a whoop whooop whoooop muffled noise you can cut the inner webbing on the exhaust hangers (middle pattern to open them up all the way in the center) - its a fairly easy repair, just prop up the mufflers, or let them hang
Old 02-15-2002, 06:43 PM
Ambidextrous Masturbator
SidVicious's Avatar
Hope this helps,
Peter.
Did you have to pay to have the tape put on? Did the sway bars have to come out to put the tape in?
Has anyone done this themselves?
Old 02-15-2002, 07:23 PM
But I just got here
Nitin's Avatar
The noises from the rear of my car were indeed because of the bushings. I had them greased and everything is fine now. Thanks for all your help here guys!
02-25-2020 09:57 AM
jblessing
08-08-2018 09:43 PM
johnpancakes014
04-08-2016 06:47 AM
wilztlxs
12-01-2015 09:16 AM
2012wagon
09-29-2015 04:21 PM
Quick Reply: Rear makes loud noises when going over bumps
