Rear CT Springs squeaking
Folks,
Just looking for some know-how here.
I got my springs installed about a month ago. Ever since, my REAR suspension squeaks over bumps. The isolators are on the Rear CT springs.
I have Koni Yellows as well. My front doesn't squeak at all.
I'm taking it back to the shop I got the work done at. I'm sure they'll fix it, but I'd like to try to save time if you guys have some feedback for me.
I took the car to the Acura dealership (which is close by) and they wrote "noise coming from aftermarket poly bushings".
Huh?
What exactly does that mean? If anyone has experience with the Koni Yellows and CT Rear Springs, your feedback is appreciated!
Thanks!
Huh?
Thanks!
Re: Rear CT Springs squeaking
Originally posted by mlrspwr
Folks,
Huh?
Thanks!
Folks,
Huh?
Thanks!
i had the same prob...it could b the grease...i had DuPont grease that washes away with water when i had my CT's put in (which makes sense b/c when i wash my car, i hose down the inner wheel well to get dirt, sand, etc off)...PAA put on regular old cargrease that won't wash away, and everything's A-OK
o, and it was the sways the squeaked like the old man's rocking chair, not the springs, even tho it SEEMS like the springs when u push down on the car
Thanx for the replies!
I got my sways installed earlier than the springs/shocks, and no squeaking until the springs/shocks got installed. No squeaking when turning (that I hear), only over bumps especially at low speeds (probably due to less road noise is why I hear them mostly at low speeds).
If OEM suspension using rubber bushings and the aftermarket stuff uses poly, then that is probably my problem. The mechanic probably just forgot to lube or teflon the poly bushings.
Good stuff and thanx.
jmoney2001
Aug 12, 2019 06:23 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
2012wagon
Sep 29, 2015 04:21 PM
