Re:ADJUSTING HIGH BEAMS
Old Oct 8, 2001 | 02:23 AM
ReflexRacing_com's Avatar
URL Not Found!
I just got blue HIGH BEAM BULBS...They seem a bit higher than the stock....how do i fix that? The tutorial i saw was for HID's only correct? thanks.
Old Oct 8, 2001 | 04:13 AM
Chris's Avatar
- daemonichris -
high beams? i don't think they can be adjusted. our hi-beams are fucked from the factory... they shine really bright about 45 degrees up
Old Oct 8, 2001 | 11:28 AM
JRock's Avatar
Old timer
Originally posted by Chris:
<STRONG>high beams? i don't think they can be adjusted. our hi-beams are fucked from the factory... they shine really bright about 45 degrees up</STRONG>
No, silly, that's because there's shiny angled bits around where the bulb is, and the light reflects off those and so it appears that the lights are shining up really high. The light are shining properly, but bits of the beam are angled up by the shiny metal pieces in the housing.
Duh.
Old Oct 8, 2001 | 01:10 PM
NOVAwhiteTypeS's Avatar
the UFO effect!
Old Oct 8, 2001 | 03:39 PM
icy CL's Avatar
aren't they suppose to be higher...that's why they're called "high beams" and are supposed to make you see a little bit further than the regular lights?
[ 10-08-2001: Message edited by: icy CL ]
Old Oct 8, 2001 | 04:33 PM
juniorbean's Avatar
Originally posted by NOVAwhiteTypeS:
<STRONG>the UFO effect!</STRONG>
Actually it's the weirdest thing... the thin light beams that reflect almost straight up are the Acura symbol. No joke, at least on the TL-S it is. I was driving through a neighborhood with trees overhanding and my fiance said, hey, that's cool, it makes the Acura "A" on the trees!! It does, check it out!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
