Rajca's Project CL-S6 Car
#322
Whats up with RDX owners?
dude, chekc out my thread about the 255/35/18 Pirelli P-Zeros on 18" x 8.0" / 48mm offset Legends. no rubbing and they are so grippy I can hardly break the tires loose unless I really pop the clutch at high rpms from a standstill, even then it's just a chirp, then it hooks right up.
https://acurazine.com/forums/2g-cl-tires-wheels-suspension-54/255-35-18-pirellis-going-next-week-737652/
#323
MOD list
-CF trunk-
-Clutch dampener removed
-SS clutch lines-
-Neuspeed short shifter kit-INSTALLED
-SS Brake lines- FONT INSTALLED
-Legend Dual Piston Calipers
-Drilled/slotted rotors- installed
-EBC Red Stuff Pads- INSTALLED
-MOGG End links- INSTALLED
-3rd gen tl Progress rear sway bar-INSTALLED
-Neuspeed strut bar-INSTALLED
-Tein basic coil overs-INSTALLED
-Tint, 10% rear, 20% front
-My custom turbo kit- PIECING IT
-Cusco under brace- INSTALLED
-Light weight 17" rims
-Gut car-DONE
-My custom radio delete gauge cover-FINISHED FOR NOW
-GM Friction Modified Syncromesh MTF
-Dot 4 Brake Fluid- DONE
-Flush and Bleed brakes-DONE
-Flush and Bleed clutch line-DONE
-Flush and refill coolant-DONE
-Intake manifold spacer-INSTALLED
-Throttle body spacer-INSTALLED
-NRG engine torque dampener- FRONT INSTALLED
-UR light weight crank pulley (oe size)-INSTALLED
-Custom nitrous setup-INSTALLED AND DONE
-CM stage 4 clutch-SAVING UP MONEY
anything im missing?
-CF trunk-
-SS clutch lines-
-Gut car-DONE
#324
MOD list
-CF trunk-
-SS clutch lines-
-Gut car-DONE
-CF trunk-
-SS clutch lines-
-Gut car-DONE
-Carbon Fiber hood
-Custom Grill
-Shift Knob
-Rear hook
-_____ Tires
#336
for got to add. i will be building an engine to with stand 600whp.
yesterday i got my plates transferred from my tl-p to my cl-s6 (sold tl-p) so i have to put on a front plate
and here is what i did
![](http://i252.photobucket.com/albums/hh9/trviper03/untitled.jpg)
anyway, i have ordered some more cf goodies. im addicted to CF.
#337
Your Friendly Canadian
Received 1,485 Likes
Damn you really are low...
Sorry I haven't caught up with 9 pages, but have you dynoed the car stock yet? What did you get?
#355
well, put on my custom test pipe. sounds nice below 2500rpm, then sounds like a cracked header or a civic with out a muffler. i still need to put in gaskets before and after the pipe. so it will change the sound. ill do that saturday or friday.
#360
