Raising The Muffler
Old Aug 1, 2001 | 02:26 PM
GRF's Avatar
GRF
Raising The Muffler
On a previous post someone had mention an idea to put a 3" clamp around the rubber grommet and tighten it to raise the muffler so that it can be even on both sides. I did that last night and it worked, however because of the clearance for the clamp it hits against the frame therefore when you go over bumps you hear it hitting. For those of you that've tried this is there something else I needed to do to prevent that? Thanks in advance for your responses
Old Aug 1, 2001 | 02:32 PM
Nightbane
Guest
Posts: n/a
Originally posted by GRF:
<STRONG>On a previous post someone had mention an idea to put a 3" clamp around the rubber grommet. </STRONG>
Would it be possible for you to post a picture or diagram of exactly were you put the clamp? Please?
Brenden
Old Aug 1, 2001 | 02:47 PM
GRF's Avatar
GRF
Brenden
I put the clamp right over the rubber grommet that hangs from the hook on the frame.
Old Aug 3, 2001 | 09:57 AM
CLS899's Avatar
Have your dealer adjust the muffler next time you go there for service.
Old Aug 3, 2001 | 11:33 AM
KCPreki11's Avatar
<STRONG>On a previous post someone had mention an idea to put a 3" clamp around the rubber grommet and tighten it to raise the muffler so that it can be even on both sides. I did that last night and it worked, however because of the clearance for the clamp it hits against the frame therefore when you go over bumps you hear it hitting. For those of you that've tried this is there something else I needed to do to prevent that? Thanks in advance for your responses</STRONG>
Couldnt u put something soft between the clamp and the frame???
Old Aug 3, 2001 | 01:52 PM
WebToker's Avatar
Originally posted by CLS899:
<STRONG>Have your dealer adjust the muffler next time you go there for service.</STRONG>
I asked them to do this and they said I needed to goto a muffler shop.
Old Aug 3, 2001 | 02:33 PM
Ogolden1's Avatar
Oh...Behave!
You need to tighten the muffler gasket!
CL-S progression 01
Jan 26, 2016 04:15 PM
DerrickW
Nov 15, 2015 05:52 PM
merc009
Sep 29, 2015 03:06 PM
johnpancakes014
Sep 27, 2015 12:58 PM
Rcelestino93
Sep 23, 2015 10:01 PM
