radius rod nut question
Old 01-18-2016 | 12:43 PM
AcuraCls6speed's Avatar
I jist replaced the bushings for my radius rods. Question is how far down are you supposed to thread the nut? It doesn't seem to get tight no matter how far I keep turning it. I believe it's only 40 something ftlb but I'm not sure how far the threads are supposed to stick out. Any information is greatly appreciated.
Old 01-18-2016 | 01:58 PM
When I did mine in the summer of 2011, I just kept tightening until I reached the 40lbf.ft on the torque wrench. I believe I used a deep socket and then a crows foot to tighten it down all the way. If possible, the manual states to replace the self-locking nut.
Old 01-18-2016 | 02:07 PM
Yeah I replaced it. So the threads were sticking out pretty far after it finally hit 40?
Old 01-18-2016 | 02:16 PM
Yeah, think of it this way. The nut (#25), on the link below, will bottom out on the radius rod washer (#15) as it sandwiches down to the end of the threads on the radius rod. My guess is, some where between there you get to 40lbf.ft. and you are good to go.
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
Just a thought, you do have the radius rod connected at the knuckle as you clamp down on the RR self-locking nut? If not, then the radius rod would spin as a result of tightening the RR nut.
AcuraCls6speed (01-18-2016)
Old 01-18-2016 | 02:34 PM
Yeah the rod is tightend down.I'll have to get a tq wrench. I have it on there no so far now. I definitely need to thread it on some more. I was just worried I was going to over tighten.
Old 01-25-2016 | 12:36 PM
fsttyms1's Avatar
you cant over tighten it. It will bottom out on the metal sleeve insert then you will tq to 40
AcuraCls6speed (01-25-2016)
Old 01-26-2016 | 11:57 AM
Threat1000's Avatar
7th Gear
tighten it again after a year and you might get 1 full turn
