Eibach sway bars
Old Apr 20, 2015 | 08:57 PM
spaceghostpurrp's Avatar
Eibach sway bars
I need some help replacing the sway bar bushings. can anyone tell tell me part numbers for both front and rear bars.
I am currently running eibach sway bars with stock end links.
Here are some pics of the end link that broke off as well as a bushing:
Attached Thumbnails Eibach sway bars-20150420_100336.jpg   Eibach sway bars-1429548961232.jpg   Eibach sway bars-1429549829771.jpg   Eibach sway bars-20150420_100346.jpg
Old Apr 20, 2015 | 09:23 PM
gnuts's Avatar
3.5 psi
You can get universal ones. I think the eibach rear is 23mm (confirm that before you order anything). Energy suspension makes them.
Old Apr 20, 2015 | 10:48 PM
i found his but i don't know which which to choose from non-grease or grease
energysuspension.com | Sway Bar & End Link Bushings
Old Apr 21, 2015 | 07:57 AM
gnuts's Avatar
3.5 psi
if you want to be able to grease them on occasion then get those. I'd just get the regular ones. Wrap the bar in plumbing Teflon tape where the bushing will touch and this will help stop any banging or squeaking.
Old Jan 20, 2016 | 05:46 PM
Little update...
I just bought a pair of Moog front sway-bar end-links to go along with a new 29mm front Eibach sway-bar. The reason being my old Eibach front sway bar cracked, breaking off one of the oem end-links along with it.
My question is are mood end-links pre-greased from factory?
If not what grease should i use?
Old Jan 20, 2016 | 05:57 PM
When I installed mine, they had a little from the factory. I could see it as I tapped the zerk fitting in; however, you are going to want to hit them with a little more.
Any type of heavy axle grease is fine, that's all I use on mine. Grease them just until you see it pass the rubber cover and wipe down.
Old Jan 20, 2016 | 06:13 PM
Pic of the bar lol
Old Jan 21, 2016 | 08:51 AM
gnuts's Avatar
3.5 psi
how did it crack? Did you hit something? That bar is pretty solid!
Old Jan 21, 2016 | 09:33 PM
@gnuts: Hahaha Idk bro. I was just cruising down a fairly flat road. The broken part of the bar (still attached to the end-link) was just dragging on the floor. Lol
Old Jan 26, 2016 | 12:00 PM
Threat1000's Avatar
7th Gear
man..i put the sway bar lins backward the first time I put the sway bar on and it popped the ball joint from the link. that sway bar if tuff. glad it didn't bend...
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hashbrown
Sep 29, 2015 12:13 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
