Radio
Radio
So im sitting in my car with the car off and the ignition on like a dummy wit my phone plugged into the charger while talking on it. So I finish my call and put my window up and noticed that the window was going up really slow so im like wtf, turns out that my battery was dead when i tried to start it but i let it sit wit the keys out for like 1 min and it started right up. Now my radio is locked up, and some how when I put in the code thats in my like manual that the original orner got when they bought the car, the code doesnt work. So now Im stuck because I dont want to pay acura no money, and the fact that I didnt buy the car from a Acura dealer I dont think I can go in there demanding it be unlocked because the code that they wrote in the book doesnt work.
Dude
Just call one of your local acura dealer and ask if they can get you the code when you have the radio's serial number or w/e it's called.
Search for the temporary solution, it's been discussed before.
I did a search on this subject before. Turn the key to the "acc" position. Make sure the radio is off and clear of any incorrect codes if so reset the headunit by disconnecting the battery. Press and hold buttons 1 & 6 on the HU. The serial number will be displayed. Give that to the dealer and they should give u the code.
Originally Posted by CLS6SpeedNupe
Is there anyway that the code could have been changed from the time the original owner bought the car up until when I got it?
I discussed this problem in my post months ago... Just go to this page and you'll find your FAST solution here that's FREE... https://acurazine.com/forums/showthr...ght=radio+code
It's in the do it yourself portion i believe. It's won rave reviews.
Originally Posted by fuzzy02CLS
To some dealers defense, a lot of them are clueless & DON'T know about that & quote an hour of labor to remove the head unit to get the # off the back.
I think having radio codes is just dumb anyway. If someone wants my POS stock radio let them have it.
I wonder will they honestly take the dash apart, or tell u to come back in 2 hour get the code through the radio, unlock it and park the car in the back. I think simple shit like this ALL dealers should should know.
There is a quick way to get the code
Open up the glove box and on the side facing you on the left there is a sticker. ON that sticke r is the code that should work!! Dealer pointed that out to me once and i have used it several times
Thank you sir, after calling around to 4 different dealers and getting the run around my radio is finally unlocked and my silent 1 hour ride to work every morning is over
You're quite welcome Acura cust care told me that trick. so... if corporate knows... the dealers MUST know... they just makin' money that's all...
after the dealer looked up the history of my car, it turns out the reason why the code i had in the book didnt work was because the original owner had problems with the orinal CD changer and had it replace but never put the new code in the book. This now also explains why I have a horrible squilling noise from my back right speaker because when they took the radio out they obviously didnt install the new one correctly.
The speaker & radio are not related. The speaker is likely blown. There are no wires in the back of the HU just a plug & harness, There's no way to mess that up. Also the HU just feeds the signal to the amp which is behind the passsanger side trunk lining.
ok the speaker is no good, that was also another thought. NoW I need to find some good inexpensive speakers to replace them with. I want to keep the base cover on them though
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
dirleton
09-28-2015 04:48 PM
