radiator overflow reservoir?
Old Jan 11, 2002 | 07:11 PM
briancl's Avatar
Just for starters I would like to say that I am a complete idiot when it comes to cars. I was able to install the high beams, but I think I messed something up. The radiator overflow reservoir has some tube going out of it. I am not sure if it is glued or something like that. I was a little rough and I accidentally detached the tube from the tank. It still goes in fine, but it's not stuck like it used to be. Is there anything that I should be worried about? Thanks
-briancl
Old Jan 11, 2002 | 07:15 PM
GOT PSI?'s Avatar
It's Go-Time.
There is a nipple under the reservoir lid and you need to re-attach the tube back on it...I think.
I hope this helps?
Old Jan 11, 2002 | 11:09 PM
briancl's Avatar
hmmm...someone from the tl site said you could unscrew the cap, and i just went to look at it and i could've unscrewed it to save from this from happening. But the problem now is that the tube which connected to the top of the tank has broken off, and all i can do is stick it in....it's not tight anymore, but just loose.
-briancl
Old Jan 12, 2002 | 12:15 AM
Rescuer's Avatar
Evil Bob Knieval
Zip Tie
spudweb
May 22, 2016 02:39 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 21, 2015 08:51 AM
