radiator overflow reservoir?
Just for starters I would like to say that I am a complete idiot when it comes to cars. I was able to install the high beams, but I think I messed something up. The radiator overflow reservoir has some tube going out of it. I am not sure if it is glued or something like that. I was a little rough and I accidentally detached the tube from the tank. It still goes in fine, but it's not stuck like it used to be. Is there anything that I should be worried about? Thanks
-briancl
-briancl
hmmm...someone from the tl site said you could unscrew the cap, and i just went to look at it and i could've unscrewed it to save from this from happening. But the problem now is that the tube which connected to the top of the tank has broken off, and all i can do is stick it in....it's not tight anymore, but just loose.
-briancl
-briancl
