Radiator Leaking from Seam
Was filling up the Wiper Fluid, and I noticed green all over the engine cover and battery cover. I looked around and noticed that the top seam of the radiator is leaking. So when I drive it comes off the top and goes inside the engine compartment.
Anyone else have problems with the radiator leaking or breaking ?
The Acura Granddaddy
Yep, I assure you this a common Honda\Acura problem. The plastic top of the radiator looses it seal to the metal part of the radiator. In the Legend community this is also a leading cause to headgasket problems down the road. As long as you get it repaired quickly there should be no problems.
Its been leaking for about a week now, and should have it repaired in a week or so when I go bring it in once the new radiator is repaired. With all the problems I've had. 3 tranny's, and these things, I'm sure thinking about getting rid of the car before the warranty runs out.
Cajun Gumbo Man
I can't believe they didn't try to blame it on the CAI or headers ......
