Quick Oil Question
Old Aug 2, 2006 | 11:14 AM
JadeFox's Avatar
yay! for SRS xtension
Quick Oil Question
the dealership wants me to use 5W-30 mobil1 in my cls ...does this SOUND RIGHT !???!?!
AND should my battery cost me 170$ canadian???? seems too high.. THANKS !!!!!!!!
Old Aug 2, 2006 | 11:19 AM
Bobbydoedoe's Avatar
I'm Cool
dealership batt=rip off, go get some die hard from sears or duralast batteries from ur local store or even get the optima. 5w30 M1 is what i use and seems right
Old Aug 2, 2006 | 11:20 AM
JZ0324's Avatar
Nope. Its not. The CLS is rated for 5w20 oil. They may be saying 5w30 due to the tempture up there.
You can use regular 5w20 or Mobil 1 5/20. Regular will be less, but the mobil one will be better for your engine and you can run it allot longer.
The new Mobil 1 you can run safely to 15k! I only run mine to about 8-9k. I just actually checked it the other day. We are at 8.5k and the oil looks good.
Old Aug 2, 2006 | 11:31 AM
JadeFox's Avatar
well normally its freezing .. but the last 2 days have been 40+ mad sweat farm...damn so 30 OR 20 ARGH!GH!G!....both should be fine no...my dela reccommended 30?!?!...isnt the battry space limited...dont we need certain batteries.??
Old Aug 2, 2006 | 12:43 PM
JadeFox's Avatar
ok ill just close my eyes and go innie meanie miney moe..
Old Aug 2, 2006 | 01:36 PM
phipark's Avatar
Not Asian
It's ok to use 5w30.
As for a battery, I have a Yellow Optima size 34/78
Old Aug 2, 2006 | 01:44 PM
mefromuic's Avatar
There was a thread similar to this before. The 01 CL's are recommended by Honda to use 5W30 and 02's and 03's are 5W20. Its in the service manual. I would use 5W20 but with a synthetic. Synthetic helps with the cold starts.
Old Aug 2, 2006 | 02:10 PM
DutchCLS's Avatar
01 CLS
i used 5w30 forever, no issues. As for battery, head down to crappy tire and pick a decent one for half of what the stealership wants.
Old Aug 2, 2006 | 02:56 PM
Kamikazee's Avatar
Skilled Wreckless Driver
Optima Yellow for the battery..
THe oil is fine. But Im all about DIY!
Stealership, jack you on price.
Old Aug 2, 2006 | 03:01 PM
TRILIGHT's Avatar
Freezing temps would demand a thinner oil instead of a thicker one. That being said, the 5W-20 and the 5W-30 oils are practically the same. I believe I read the only reason the spec was changed was to conform to some government standards or something. Given the freezing temps up there, I would try to find the 5W-20 if you can but it won't necessarily hurt anything to use 5W-30.
Old Aug 3, 2006 | 12:55 AM
JadeFox's Avatar
i think i screwed up... I believe i put in 10w30...i found my old stealership reciept...my previous oil was 5w-20....what the hell did i just do????
Old Aug 3, 2006 | 01:14 AM
Kamikazee's Avatar
Your not gunna die..promise.
Old Aug 3, 2006 | 11:30 AM
JadeFox's Avatar
i must be an egghead..should i go and change it all out???
Old Aug 3, 2006 | 02:27 PM
Starter's Avatar
It won't hurt to run that oil for a while.
As to the 5-20 vs 5-30 debate, Honda (and Acura of course) changed the recommended oil as a partial way to meet the last round of fuel economy standards as in 5-20 gives ever so slightly less resistance to moving parts. There was absolutely no change in the engine internals. By the way, Ford did the same thing at the same time for the same reason.
Old Aug 3, 2006 | 04:13 PM
fender4's Avatar
BINGO,, what he said,, oil vis change was for EPA numbers only,,
Now if you just use 0w30 Amsoil with a Amsoil filter you'll be good for one year or well over 10k miles. Amsoil 0w30 has been made to exceed all 5w20 requirements. I do this after I had my oil analysed,, it works great,,
It's hard to get past the fear of unknown,, just read more oil stuff on the internet.
A good place to start www.bobistheoilguy.com
Old Aug 7, 2006 | 10:06 AM
JadeFox's Avatar
ok well, i put mobil1 10w30 in. It eliminated this "clunk" that i heard everytime i started the car, the redline even made the sound...
Old Aug 7, 2006 | 10:50 AM
MISTAZOOM's Avatar
2003 CL-S 6SPD
Even though everything is built to spec, each engine is its own entity and has its own characteristics. I usually use 5w 20 but i will venture and try other things to see what my lil guy likes best. Next ill try the 0w30 Amsoil stuff seeing that so many have said fantastic things about it.
Old Aug 7, 2006 | 10:52 AM
MISTAZOOM's Avatar
2003 CL-S 6SPD
Even though everything is built to spec, each engine is its own entity and has its own characteristics. I usually use 5w 20 but i will venture and try other things to see what my lil guy likes best. Next to try will be 0w30 Amsoil. Heard many many good things about this stuff.
bungln
Feb 20, 2019 08:47 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
IIDXholic
Oct 8, 2015 07:53 AM
datadr
Sep 12, 2015 09:12 PM
