Questions about car, Headliner sound?
HI,
Just picked up my Cl yesterday and there are a few things which i am wondering about. First i believe that after a certain period of time the doors lock after the engine is off and you are outside the car. Do you know the exact time period and can this be turned off. Second i read that the side view mirrors should turn down when you are in reverse, this only works on my passenger side, maybe it's meant to be like that but today now none of them turn down when in reverse, any way to fix that. Third is when i sit in the back of the car when driving, when it hits a bump in the road a sound like cruching styroform is able to be heard, i think it i coming from the headliner. How can this be fixed, i'm pretty sure this is different from the sunroof rattle. The middle tray box thing in the rear seat is jammed now, is there a way to open it or should i just leave it to the dealer. THanks.
Re: Questions about car, Headliner sound?
AFAIK The doors only re-lock if you have used the alarm unlock function and don't open a door.
Only the passenger side goes down. You must have the mirror switch set to the center position the feature does not.
You may have a headliner squeak but... the sunroof squeak is mistical. You will hear it from everywhere. Get it fixed first then you can track down the other smaller squeaks.
Take the stuck box to the dealer. You might just break it trying to fix it.
Make sure you check out Chods FAQ for lots of answers to your questions.
If you unlock your doors with the FOB, they will automatically relock if you don't open your doors in like 30 seconds or something.
Your car doesn't automatically lock itself otherwise. (Side note: It is semi-difficult to lock your keys in your car.)
handsom-hustla
Nov 13, 2015 05:04 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
