Question on Power
Old Aug 11, 2007 | 01:53 AM
  #41
Blasted69's Avatar
03 Anth Type S 6 Speed
I mean I wonder if the stock suspension helps with the ability to screech 2nd gear. Maybe its the way the tires are laying on the ground.
Also how are the roads where you live. I know on certain roads I can really get a loud chirp in 2nd. It seems like on fairly new paved roads its really easy to chirp the tires.
Old Aug 11, 2007 | 03:59 AM
  #42
kyle77777's Avatar
Gonna cost to catch up
Im lowered 2" on eibach springs
Old Aug 11, 2007 | 12:18 PM
  #43
Blasted69's Avatar
Ah, I got you confused with fsttyms.
Old Aug 13, 2007 | 01:40 AM
  #44
SPoolinspOON's Avatar
OG 3.x^7 rawr
hmm.... I remember when I was stock I could chirp 3rd pretty easy.
After intake, bored TB, and Headers....1st spins like crazy when VTEC engages, 2nd gear spins all thru VTEC with a little traction, and 3rd is a feather spin, like I have to counter the steering.
Old Aug 13, 2007 | 08:03 AM
  #45
omg_its_the_2.3's Avatar
what does chrip mean?
Old Aug 13, 2007 | 09:48 AM
  #46
Blasted69's Avatar
when you shift gears and your tires spin and you get the little screech.
Old Aug 13, 2007 | 11:03 AM
  #47
implicit's Avatar
eh
If I dump the clutch I can light up the tires going from 1st to 2nd (which I almost never do...). If you can't - assume weak clutch or really sticky tires - I'm still running stock size V rated but they are brand new.
Old Aug 13, 2007 | 11:11 AM
  #48
black label's Avatar
Trolling Canuckistan
Originally Posted by nbennettksu
43psi is way too high. I never put air in tires above 37psi and thats pushing it, usually around 35psi. Unless its a truck...then you really dont need to be over 35pounds per square inch...
You can do some interesting things to the handling charecteristics a front drive car with tire pressure adjustments. That said 43psi still seems high unless you are driving at consistent speeds upwards of 110mph in which case you want the extra pressure to deal with the increased tire temperature.
My 97 prelude's owners manual said to pump up to 40psi if you were going to drive at a consistent speed over 100mph (along with the warning to follow local speeding laws).
Old Aug 13, 2007 | 12:58 PM
  #49
Blasted69's Avatar
I don't understand this. I can spin 1st when vtec kicks in and since the PSI adjustment I can give a nice screech in 2nd. I can not however chirp 3rd, I have CAI/H/E and pully goin in soon. I don't understand how you could chirp 3rd easy while stock...
Old Aug 13, 2007 | 01:06 PM
  #50
kyle77777's Avatar
I can do this as well, not always though. Depends on the pavement Im guessing or my tires (toyo proxes)
Old Aug 13, 2007 | 01:10 PM
  #51
Blasted69's Avatar
I dunno, I'm on Proxies as well. I've only chirped 3rd once, and it was when I was racing a new G35.(this was back in 04ish) Got him by 2 lengths.
Old Aug 13, 2007 | 01:15 PM
  #52
OG 3.x^7 rawr
i'm running proxies. I think its because of HP went up, torque numbers went down a bit? Smoother power band? I dunno.............
Old Aug 13, 2007 | 03:14 PM
  #53
Blasted69's Avatar
A lot of it has to do with the roads that you are driving on. Some are really easy to light them up on and others are near impossible
Old Aug 13, 2007 | 08:47 PM
  #54
thrty8street's Avatar
your mounts could be wearing out
Old Aug 13, 2007 | 10:06 PM
  #55
Blasted69's Avatar
why would mounts affect this?
Old Aug 14, 2007 | 12:00 PM
  #56
The rubber in the mounts may be wearing out making them softer and prone to movement. The weaker mounts make your engine move more therefore not all power is put down on the ground. Some power is lost through the engine moving.
Old Aug 14, 2007 | 12:40 PM
  #57
Blasted69's Avatar
ah, I see. Is it normal for them to go after 45k?
Old Aug 14, 2007 | 03:19 PM
  #58
fsttyms1's Avatar
Ive seen them fail with half that on them
Old Aug 16, 2007 | 10:08 AM
  #59
Blasted69's Avatar
How do you test to see if they are bad?
Old Aug 16, 2007 | 10:32 AM
  #60
Tweek's Avatar
Caffenine Addict
Why are you even trying to compare "Chirping tires" to a power measurement. Besides the fact that everytime you "chrip" your tires your eating away your cluth, expensive tires, engine mounts, etc.
Many variables come into play when you are trying to "chirp" tires. Suspension setup, wheels alignment, tire compound, tire pressure, road texture, blah blah blah. If you really want to see how much power you has gained with your mods go get your car dyno'd. Save the wear and tear on the car. If you are really into chirping your tires just mount up 2 spare tires up front and chirp away.
Old Aug 16, 2007 | 11:27 PM
  #61
Blasted69's Avatar
I was just making a comment on how after my mods I wasn't able to do what I use to be able to bone stock.
I in no way was using it to gauge my power gains, I would use nothing except for a dyno to do that.
Just making an observation and seeing what other people thought. That IS what a forum is for isn't it?
Old Aug 17, 2007 | 01:19 AM
  #62
gc86's Avatar
Advance
Originally Posted by fsttyms1
chirp?? man i get lots of wheel spin going into 2nd and the chirp into 3rd
x2 and my CL-S6 was my first manual, it was actually more like a bark going into 3rd
I had brand new 225/45/17 tires though at 32psi and my car was stock.
Old Aug 17, 2007 | 06:16 PM
  #63
Blasted69's Avatar
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 17, 2015 09:01 PM
datadr
Sep 12, 2015 09:12 PM
