Question on Konis
Old Nov 28, 2001 | 07:05 PM
H@mmerm@n's Avatar
My other car is a 350Z
Question on Konis
I bought the Koni yellows several months ago because I heard they were fully adjustable. I understood this to mean ride height and rebound/damping were adjustable. After I bought them but before I had them installed, I found that only the rebound/damping was easily adjustable at the shock (with the white clicky-thingy knob :P ) , and I figured that I just misunderstood when I thought they were height adjustable.
Can someone explain how the perch can affect ride height? Does the upper perch give you the lowest ride height, and the lowest perch the highest ride height, or vice-versa? How much difference in ride height does it make either way? Any recommendations? Is there anyway I can easily tell which perch my car was set at?
Old Nov 28, 2001 | 07:15 PM
blazerbob1's Avatar
Comes with perch ring in the upper position which is recommended unless used for racing. Lower perch would lower another 1-2inches! Would not recommend that if you want to have a decent ride and no rubbing problems! Koni Yellows are adjustable for stiffness. I have mine adj. 10clicks rear and 8 clicks on front. Car feels pretty neutral with that setting though on the stiff side! Can hardly wait till I upgrade my tires. Goodluck!
Old Nov 28, 2001 | 08:31 PM
H@mmerm@n's Avatar
Thanks for the info. I've had the Konis for a while, but I just got new wheels and tires. I'm not anticipating any rubbing with the current setup since other CL owners with the same setup have reported no rubbing isssues. Just wondering about what adjustability exactly means...
I have both my front and rear Konis set at 1/2 turn. How much is a click?
Old Nov 28, 2001 | 10:55 PM
blazerbob1's Avatar
To adjust Koni Yellows start from softest setting and begin to turn in direction of arrow on the dial. You will feel it click with each turn. My adjustment was 10 for the rear and 8 for the fronts! This is pretty stiff setting but the car is neutral and my wife doesn't mind the ride!
Old Nov 29, 2001 | 04:04 AM
Amir's Avatar
BigPimpShyne
damn, so koni's are a lot better than the tokico...on a scale of 2-11, how bad do i need to get them bitches with my drop...im feelin tha neuspeed springs right now, but im leaning towards the comptechs because they arent that dependant on the shocks...Shyne
Old Nov 29, 2001 | 10:47 AM
technoid's Avatar
To adjust Koni Yellows start from softest setting and begin to turn in direction of arrow on the dial. You will feel it click with each turn...
That's wierd.
My Koni's (from AutoCarParts.com) didn't "click" when I turned the white "clicky-thingy knob." I used the raised markings every 1/8 of a revolution on the edge of the knob to tell me when I turned the shock adjustment to where I wanted the setting (i.e. 3/8 or 1/2 turn).
BTW, increasing the firmness of the Koni's to a full turn made a big difference in the cornering, but I backed off that setting, choosing instead to sacrifice a little handling to regain some ride comfort.
Old Nov 29, 2001 | 10:59 AM
fbazakos's Avatar
on bin laden
Originally posted by technoid
That's wierd.
yeah, same here, mine don't make a clicky sound, or have a clicky feeling. it is a smooth rotation, ie: infinite adjustment.
Old Nov 29, 2001 | 12:37 PM
technoid's Avatar
fbazakos,
Hmmm...what is Acura part no. 77237-SOK-A02 ??
Old Nov 29, 2001 | 12:38 PM
technoid's Avatar
fbazakos,
That's not the new cup holder, is it?
Old Nov 29, 2001 | 12:59 PM
H@mmerm@n's Avatar
My adjustment of the Koni's is "click-free" as well.
I read a lot of info and FAQs on the Koni web site. It explained the difference between compression (ie., bump) damping and rebound damping. Good reading.
Old Nov 30, 2001 | 10:36 AM
blazerbob1's Avatar
My bad dudes. I was going from memory on the clicks. I think it must be a little fall out from previous clicky things posted here on the board! Actually to be very precise like I was trying to be and am meticulous about such things, there are ribs on the Koni adjustable dial. 10 ribs of the dial from set point on the rears and 8 ribs from set point on the front!
Old Nov 30, 2001 | 10:46 AM
fbazakos's Avatar
on bin laden
yep.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
