Question for CL navi owners
Looking at the above part diagram, on the DVD bracket (#3), there are 2 screws holding up the rear (#13). What is holding up the front? I understand that the metal bracket also folds and tucks into the rear deck but on my car there is also a hole in the bracket and a bolt that extends down from the deck and it seems like there should be a nut for each side on the front opposite #13. I do not see such a nut listed in the part diagram.
Does anyone actually know if there is a nut there or not?
Yes, there's two bolts welded into the rear deck that attach to the two angles on the front of the DVD unit's bracket. Doesn't look like the nuts to attach the front of the bracket is listed there, for whatever reason. Check up under your rear deck and you should be able to see the two bolts poking down.
Yeah, there are two nuts that hold the front of the bracket up, but I don't seem them listed on that diagram, nor in the list of parts. Probably the best thing to do it head over to lowes and find two nuts that fit those two bolts, and maybe some lock washers too. I remember having to re-tighten them after a while when I did my navi conversion.
mugen_kid
Nov 13, 2015 10:38 PM
lovic87
Sep 9, 2015 10:18 AM
asahrts
Sep 4, 2015 05:55 PM
