question bout rotora brake kit
hi my name is Anthony and i bought the front rotora brake kit and axis pads but i get a sqeaking noise as if i need new brakes can some 1 tell me what pads to put on to stop the sqeaking ...stock ones from acura.....or better ones then i have let me know
Squeeking?.... from the rears?....
The Rotora FRONT big brake kit comes with pads... so if you upgraded the rear pads to axxis pads when you put the new rotors on the rears then you have nothing to worry about. the squeeking is either the pads seating themselves, a cocked pad, or you needed to adjust your e-brake since the shoes will sometimes rub the inside of the rotor drum.
Just try and explain your problem to me as best as you can, i will try to help.
Smitty
Smitty
nuldabz
09-03-2015 05:49 PM
