a question about wheel sizs
Old Feb 22, 2002 | 09:54 PM
ItalianStallion's Avatar
I Feel Too Old Here
when looking into rims, what width is best for an 01 it the desired diameter is 19? ex/ 19x8.5 or what?
Old Feb 22, 2002 | 10:07 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
It depends, are you planning on dropping your car? If so by how much? I sure hope so.
On our cars, I really think you shouldn't try anything more than 8" wide wheels.
With that wide of a wheel, you should try not to get anything lower than +45 offset to make it look nice w/o it sticking out past the fender like an SUV. That would be the limit, a +48 or above is better for 19x8" wheels.
The CL-S has more clearence than the TL/S.
If you can, try and find a 7.5 wide wheel to minimize the possibility of a great amount of rubbing. You will have an easier time making it fit and if there are lower offsets than +45 only available.
Old Feb 22, 2002 | 10:11 PM
AztecRol's Avatar
The Screeching Toyo's
This should help a little bit.
Our stock offset is +55 and stock rim is 7 in
offset calculator
one more
this one is to make sure your speedo is still ok
235/35 19 is perfect to replace our stock tires
tire size calculator
Old Feb 23, 2002 | 02:19 AM
Nicky Pass's Avatar
Fuct in the hed!
You should be fine with a +45 offset.......thats what I have.
Old Feb 23, 2002 | 02:30 AM
EricL's Avatar
If you drop the car a bit, the +45 offset with 235 rubber could be a problem; there is a possibility of rubbing on the rear fender lip if lowered.
In a 19x8, the +50-+52 offset seems to work well with 2" lowering.
If you're talking about a non-lowered car, then +45 will work with 7" to 8" wide wheels.
The offset, wheel width, wheel and tire diameter, and tire profile and size, along with drop, bump stop changes and/or shocks can all make a difference between a setup that works without rubbing and/or one that will drive you crazy...
Old Feb 23, 2002 | 05:59 PM
I Feel Too Old Here
where could i find the offset when im looking at em on superbuytires.com?
Old Feb 23, 2002 | 07:01 PM
I Feel Too Old Here
ok now so i emliminated the zenetti mystik in 19 and 18 cause the width is 8 for the 18 and 8.5 for the 19. i found another brand (diablo) that makes a wheel (burgini) in the same style but it is in 17, 18, and 20 only and NO 19 so here's the situation, 18x7.5 with no drop. ideally i dont want any scuffing if possible, would it scuff? im still looking for what available offsets they have.
booma1218
May 3, 2016 07:39 AM
lland
Oct 4, 2015 04:47 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
bailey24
Aug 31, 2015 05:38 PM
