Question about mating...
Old Oct 11, 2012 | 08:19 PM
yungone501's Avatar
J-series addict
Mating an engine and transmission that is you nasty perverts!
No, really. I had a strange idea today but before attempting any move, I wanted to first gather some unprecedented knowledge from my fellow members here. Now that I've buttered everyone up to give exceptional advice, here we go.
I need to know if my transmission from my old J32A2 (from an 03 TL-S) engine would bolt up to a J35A6 (from an 05 Odyssey) engine? Would it be direct replacement in terms of mating the two. I'm 100% aware that there are various other things that will need to be done in order to have them operate together.
And please, to help avoid any confusion or conflict, if you're not sure about any information with this PLEASE don't contribute. I appreciate everybody's help and will not forget about you next time you have any electrical problem on your car! :-)
Old Oct 12, 2012 | 02:50 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i think the 3.5 and 3.2 transmission swap both ways. cannot work without adapter plate.
could be wrong tho
Old Oct 12, 2012 | 04:35 AM
Atlas.46's Avatar
I can't remem where... but someone was talking about block castings changing or something... can't remember which years/engines
Old Oct 12, 2012 | 07:06 AM
yungone501's Avatar
J-series addict
But doesn't an 04-05 Odyssey transmission bolt straight up to our motors and that's one one of the most popular swaps...just the other way around?
Old Oct 12, 2012 | 08:56 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
I would assume it would bolt up.
If there was a issue it might be between the flex plate and convertor witch would be nothing.
reason I say this is I have a newer tl trans and that year oddessy is supposed to have the same bolt pattern. But once I installed the j37 crank in the j32 block. when the flex plate was bolted to the crank it sat right against the crank seal cover and I had to make a spacer to make everything fit.
I am not sure if the crank is shorter. If it is then you might have enough to slide the convertor a little more forward or make so kind of spacer if needed.
Just speculating.
Karanx7's Avatar
Unregistered Member
I know the 3.5L engines from the 3G TL-S has a different housing pattern, but I think the odyssey will mate up just fine.
Old Oct 12, 2012 | 09:00 AM
That's what you should find out.
If 05 oddessy and newer tl type s would work.
Ask tha nva6 dude or what ever his name is.
He does alot of swaps.
iva always wondered how it would feel to have a van tranny in a coupe.... i know they are they same ISH but still that would never leave my conscience.
Old Oct 12, 2012 | 11:37 AM
yungone501's Avatar
J-series addict
Thats actually who I'm going to call here in a bit. I thought late 06 and early 07 TL-S' have the different 'newer' style bellhousings btw...
Old Oct 17, 2012 | 11:08 PM
aznboi2424's Avatar
Your pretty much correct and also right that the 05 trans will bolt up to your TL-S.
I'm guessing you've looked at the 3G TL/Oddy trans thread right?
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
