question about big brake kit on stock wheels
Regional Coordinator (Texas)
so i did some search and found out that u need a 5mm spacer to make the stock CLS wheels fit on a BBK (specifically Rotora BBK).
Can some one confirm this.
Also is this for CLS wheels from 01-02, or 03 or both.
Stock TL or CL wheels, 01-02 or 03 will not fit the Rotora Single piece rotor and 4 piston caliper. A 5 mm spacer is needed. 04+ TL wheels will clear with no problem. As will our wheels.
a 2 piece rotor is even more difficult and may require more than 10mm of clearance.
Former Sponsor
I always seem to forget about the second gen
BTW, if you want to keep the stock looking split spoke 03 wheels, the 07-08 base model TL wheels are very similar, and they should clear without a spacer.
i tried fitting an 01 CLS wheel on a 2 piece Rotora with 5mm spacer and that didnt work. not even with about 7-8mm. and when i tried a bigger spacer, i barely had any room to tighten the lug nuts so i'll prolly need longer studs.
Former Sponsor
Only the 1 pc disc BBK will fit with a 5mm spacer. The 2 pc disc is 7mm wider than the 1 pc disc and will require a larger spacer and longer studs.
Yes - same specs - 17X7 w +55mm offset
I ran the '03 CL-S wheels with the Rotora 1 piece rotors using a 5mm spacer without a problem. Tight fit but it worked fine.
nuldabz
Sep 3, 2015 05:49 PM
