put my remote start in yesterday
I finally put my remote start in yesterday. Me and my friend did it, bypassed the clutch and its on a 3 pulse system so i push the unlock button 3 times and it starts. Definitely convenient for these 5 degree mornings. I highly recommend it, only problem is that you can't have it installed on a stickshift car by an audio place cuz its "illegal"
Daring guy you are.
I would NEVER put an auto-start on a manual unless there was some kind of neutral safety switch.
I knew a guy who drove his car into a tree because he forgot and let it in first gear when parked.
As he was running towards the car it bucked and stuttered a few times and then shut off. He thought he was safe and then the system attempted to start the car again.
BAM…. Right into a tree.
They are illegal for a reason. The only way to safely install one is to have a sensor that “knows” if the car is in neutral.
Shawn S
Shawn S
Originally posted by ch1276
they put an extra key in a key reader and hide it somewhere in the car
ive heard that if you remote start and hit the brakes the car shuts off.
sidemarker
Originally posted by sidemarker
so you pretty much dont need your keys. how do you turn the car off?
sidemarker
sidemarker
The extra key usually has the tip broken off so it won't function properly in the ignition. It's in the car for the transponder it holds.
[QUOTE]Originally posted by Bulldog01
[B]My car will turn off if I don't put the key in the ignition and turn it to ON after a set period of time, or if I press the brake pedal before putting the key in and turning it to ON
Mine does the same thing.....
right, but Wouldnt it be 'scarey' because I'm sure theres a lot of peeps out there that know about our cars enouh to know about that. and once the alarm is defused...then they got the key and everything.....
I guess there is no need...because if someone really wants your car...they'll get it anyways..
ok here's the deal, A-it has a kill switch, B-the key does not have to be in the ignition there is a transponder box which my valet key goes in which makes it possible to start the car. C-to get the car to move you have to put the key to accessory and press on the brake. D-to get into the car you also need to unlock the door with the key E-the name of the brand is "Valet"...F-nobody can drive away with it because the steering locks and once you touch the brake the car shuts off, plus nobody knows where i hid the extra key inside the car. I think thats everything, and for the guy who said he doesn't need it in LA, it can also be used on hot days where you can put the AC on.
Originally posted by CBR1100XX
Only dipshits leave there car in gear when it is parked. that is what the parking brake is for.
I ALWAYS pull the E-Brake and put it in first when I park.
I don’t trust the parking brake, especially on a hill. :shakehd:
Shawn S
Great...its always good when someone takes the time to explain the whole thing. All that info makes me feel more comfortable for when I purchase mine then....just was unclear about some things
I am so glad I am not a dipshit anymore I have an automatic transmission on my TL now.
ok maybe dip shit was harsh. you guys may be doing it the right way. My reason for not doing it is I have had 2 vehicles hit in parking lots, and would hate to have a small cosmetic collision be the cause of something much larger because I had the car in gear. it just seem slike it would be very jarring to motor mounts ect... Also people don't tend to stick around and give you there insurance info. Lastly, Houston is flatter than shit. no hills to worry about.
the key has some sort of chip in it!
