Pulleys
Old Jul 21, 2007 | 11:20 AM
  #41
Blasted69's Avatar
03 Anth Type S 6 Speed
Originally Posted by Blasted69
http://www.unorthodoxracing.com/Merc...Code=clultraSc
Is that the correct pulley for an 03 CL-s 6sp?
Whats the difference between Stock Diamiter and Underdrive pulleys? Which do I get? Which one uses the K040425 & K060441 belts?
Also what is the difference in the Tuner Series? Will they all fit the same belts?
Sorry for so many questions, I just don't want to get the wrong thing.
If you could please link me to the one that I should get.
Thank you very much
Anyone? plz
Old Jul 21, 2007 | 12:25 PM
  #42
aackshun's Avatar
Confused Maxima Owner
^ I'm quite sure man the differences in the 6sp/5at aren't at the crank (then again I am still n00bish on this forum)
Old Jul 21, 2007 | 01:24 PM
  #43
fuzzy02CLS's Avatar
Thank you very much
1-Put in your car info on the website. Same part for 6mt or auto.
2- Stock diameter means the crank pulley is the same size as stock, but is lightweight. It uses the same stock belts. You get some power gain.
Under drive means the crank pulley is a different size to under drive the crank. You get more power from this as well as the weight reduction.
This uses the 2 new belts posted.
3- Don't know
Old Jul 21, 2007 | 03:16 PM
  #44
Blasted69's Avatar
3- Don't know
Your the man, thanks!!
Old Aug 26, 2007 | 10:58 PM
  #45
j1eight7's Avatar
T.O. Advance
it says on the unorthodox website that the underdrive accessory pulleys don't allow the the ac and whatnot to charge up? does the underdrive set come with stock size accessory pulleys? is anyone having any problems with their air conditioning or alternator?
Old Aug 27, 2007 | 12:13 AM
  #46
TCM 01 CL-S's Avatar
Uses turn signals in my
No problem with A/C over here and it gets 90+ degree's F easy. The UD pulley only comes with the UD pulley unless you buy the set.
Old Aug 27, 2007 | 09:51 AM
  #47
Excelerate's Avatar
Former Sponsor
I think you are misinterpreting something on their website. Nowhere on their website does it say the underdrive pulley doesn't allow the A/C to charge. The underdrive pulley on average underdrives the accessories by about 10-20%, most being in the 15% range. If you have a large stereo (over 600 watts RMS) or a supercharger then you do not want to underdrive your accessories at all. Otherwise, doing so, will not affect your accessories in a way that you will notice it or be detrimental to the performance of your vehicle.
Old Aug 27, 2007 | 02:26 PM
  #48
shiftityourself's Avatar
Does that only refer to the accessory pulley? Can I run just the underdrive crank pulley with a 600+ RMS sub (more like 1100 RMS)?
Old Aug 27, 2007 | 05:45 PM
  #49
Excelerate's Avatar
Former Sponsor
The crank pulley is what underdrives the system so you would run the stock size crank pulley or stock size pulley kit.
Old Aug 27, 2007 | 08:26 PM
  #50
Blasted69's Avatar
I have 2 12's and a 600 watt amp, does that mean I shouldn't get the underdrive pulley? I doubt I am using all 600 watts, or am I?
Old Aug 27, 2007 | 10:56 PM
  #51
j1eight7's Avatar
T.O. Advance
i was looking for the stock size set on the unorthodox website. but when i click on the button, the info isn't there anymore.
Old Aug 28, 2007 | 10:27 AM
  #52
Excelerate's Avatar
Former Sponsor
Is it 600 watts continuous or 600 watts RMS? Check the rating on the company's website. If it is continuous you can use the underdrive pulley.
Old Aug 28, 2007 | 10:28 AM
  #53
Excelerate's Avatar
Former Sponsor
If you need it just PM me. I just ordered a set the other day.
Old Aug 28, 2007 | 11:40 AM
  #54
Blasted69's Avatar
http://www.dealtime.com/xPF-Bazooka-EL1500
This is the amp that I have. I am using the Stock HU and all stock speakers. I also have 2 MTX 12's in a box in the trunk.
Will I be ok with underdrive pulley?
Thanks again
Old Aug 28, 2007 | 04:36 PM
  #55
BigLizard's Avatar
Moderator Alumnus
Thanks again
You'll be fine.
Old Aug 28, 2007 | 06:02 PM
  #56
jlspeed29's Avatar
so wheres the guy testing the ebay 1....are we waiting for his car to take a major Sh$t? hahaha
Old Aug 28, 2007 | 07:42 PM
  #57
Blasted69's Avatar
Yeah the crank pulley is not something that I would go cheapo on. It is crazy to do so. I mean for around 200 you can get a proven great quality part with great power gains.
I can just imagine the one from ebay is probably not perfectly round and i can envision it breaking apart because it is a cheap POS. That is one of the major things you do not want to skimp on.
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
thegipper
Oct 21, 2015 07:19 AM
iCrap
Sep 11, 2015 06:21 PM
