Problems? need thought..
Old May 2, 2002 | 12:24 PM
Smitty02CLs's Avatar
2002 CLs w/Navi
Went out to lunch today and it took a few times to get my car cranked up, it usually fires right up. Anyone heard of this, is was only sitting for 4-3 hours.
thanks
Old May 2, 2002 | 12:32 PM
AcuraFanatic's Avatar
('''\_(o_0)_/''')
There's infinite possibilites as to why it did this. And this may have just been a one time event, given the numerous conditions present may not be able to be reproduced.
A few things could have happened...and you need to ask yourself these questions.
1) Were any electronic devices on, such as radio, or the A/C. This will drain the battery when you turn the car off, and may lead to slow ignition.
2) How much fuel was in the tank?
3) Was there a dramatic temperature change during that time period?
If the problem persists, it could be a bad battery or ignition, which Acura will replace under warranty.
Good luck.
Old May 2, 2002 | 12:34 PM
briancl's Avatar
my car has done this before. im not really worried because if it keeps happening, then i'll just take it to the dealer. you should be fine unless it happens often.
-briancl
Old May 2, 2002 | 01:01 PM
2002 CLs w/Navi
yes this was the first time it's happened, the battery is fine, it has the normal juice. Just kinda weird that I had to turn it over twice , won't worry about it unless it happens again
Old May 2, 2002 | 02:59 PM
mattg's Avatar
there is a tsb for this problem, take it to the dealer. they may replace your computer and fuel pressure regulator.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
