Problems: LIPPSTUH'S JERKING
Alright, so far I have replaced spark plugs and primary o2 sensor. Still have CEL and still have the symptoms
I had a feeling that the o2 sensor wouldn't cause this problem, but at the time it was the only code that came up.
Symptoms: From time to time (sometimes its frequent sometimes not) when I accelerate (esp slower acceleration) i will get a cut off gas (or so it feels like). I would keep a steady foot then it doesn't keep accelerating. So i keep pressing the gas pedal down. then suddenly it will jerk a bit because it'll start accelerating all of a sudden. so there's a lag. sometimes when this happens, i will let go of gas and gas it again and it doesn't create that lag.
and no its not a clutch related problem.
i THINK its ignition coils because a few people had this problem and said that's what fixed it, when I replaced spark plugs i didn't notice anything wrong. but whatever. what do you guys think?
I was going to post about about this sooner or later - but i also, as of late, have been noticing sort of the same thing --- only mines sort of a very slight, but very noticable hesitation...
Same symptoms, have only noticed it going slower speeds/lower RPMs - definately not clutch and definately not driver induced...
My throttle only cuts off for a split second then resumes as normal, doesnt stay "cut off" for longer than that.
Have noticed it 3 times in the last month and a half or so.
OG 3.x^7 rawr
mine has been doing the same...I did notice on mine that it occuring in the morning. I'll cruise at about 30mph and then there is a slight jerk, like a fuel cut off, and then resume...
MP90 uninstalled
Originally Posted by LIPPSTUH
they don't do that anymoreeee
I have noticed the jerk too. I get it sometimes after starting the car and driving between 30-40mph at a constant throttle input. It is a drop in power for about .3 seconds and then everything is normal for the rest of the drive. It usually happens only within the first 5 miles of driving. I really noticed it after I put the blower on but it is not on now and it has done it without it. Jim
Originally Posted by Allout
Have you checked for vacume leaks?
i ran the obd-II and it STILL says that I have p0132
O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor1)
sorry to bring back an old thread, but did you ever figure out what the problem was?? I've been having the same symptoms for a couple weeks now, and finally the car threw a P0132 code... I have searched a couple threads with similar problems but as far as I know no one had any luck with a solution.
This is what I got driving from NC to Boston last week and I am really happy with the mileage I got. This was also sitting on the interstate for an hour dead stop and driving around in Boston.
