Problems with the FP
Old Apr 30, 2006 | 07:26 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
I havent driven my car for months now because of a few things i am doing (still not done) but I start it once a week and keep it running for about 5-10 minutes.
I noticed that my FP at idle is 33-34 lbs and vac is 20. I know I am supposed to be at 42 lbs at idle with the HBP. I dont know what it is but now that I am thinking about it I have always had low fuel pressure with exception to the first week I had the SC put in. I always went passed 100 lbs and now it will reach maybe 90.
Is it possible that my FPR needs to be tweeked? by the way max boost seems low too and runs about 4-4.5 lbs MAX. Any thing I should do or can adjust myself?
Thank you.
Old Apr 30, 2006 | 07:52 PM
italiaCLs's Avatar
id like to be about 7.5-8 lbs is this possible? smaller Sc shaft pulley? bigger alt pulley?
Old Apr 30, 2006 | 10:34 PM
italiaCLs's Avatar
Old May 1, 2006 | 03:14 PM
italiaCLs's Avatar
Old May 1, 2006 | 03:21 PM
cl8trr's Avatar
turbo!!
Old May 1, 2006 | 03:43 PM
italiaCLs's Avatar
Originally Posted by cl8trr
turbo!!
no. no turbo needed. Just some help with my Fuel pressure/Boost Problem.
Making a pulley to make the SC run about 7.5-8 PSI is very possible. As long as you dont run the Blower beyong 16,000 RPM i beleive, which is around 10 lbs of boost. I just want a little extra something. I just dont know where to start.
Can anyone help me with my problem.
Thankyou
Old May 1, 2006 | 05:49 PM
mrsteve's Avatar
Tighten the belt. If you aren't seeing full boost you may not see full fuel pressure as the FPR is a rising rate regulator and as boost pressure rises fuel pressure will as well.
If that doesn't work I'd check the gauges and lastly check the regulator. Purchase a manual fuel pressure gauge (they are only $40) and test the fuel pressure directly at the regulator fitting where you currently have the fuel pressure gauge sensor installed.
Old May 2, 2006 | 08:20 AM
italiaCLs's Avatar
My belt is already tightened.. I checked that already. Where could I pick up a FP gauge for $40?
MrSteve
PS-Do you know where I can pick up a max boost pulley and what else is needed besides the pulley to do the job right? injecters? Tuning of the FPR? im looking for about 7.5-8 lbs.
Old May 2, 2006 | 09:21 AM
mrsteve's Avatar
You'd need an intercooler or injectors/methanol injection.
Old May 2, 2006 | 04:19 PM
italiaCLs's Avatar
No front mounts though. Is the only one Hope system's? is the FM an option?
An intercooler would help with detination as well as a methonol setup would?
Correct me if im wrong.
Thanks again
Old May 2, 2006 | 04:29 PM
mrsteve's Avatar
you could use a front mount
Old May 2, 2006 | 09:33 PM
italiaCLs's Avatar
Sounds good. I think im going to take that route. Any suggestions on what size intercooler to use? Also I need that higher boost pulley too. Know where I can get that? Ill be doing this sooner than later.
Thanks again MrSteve
Old May 2, 2006 | 09:41 PM
mrsteve's Avatar
Not sure about the pulley.
Send BlueCLS6 a PM and ask him for the part number on the intercooler.
You'll need the e-manage too in order to retard timing and add injector pulse width too if you up the boost.
Old May 2, 2006 | 10:01 PM
italiaCLs's Avatar
Ok. Sounds good.
Thanks for your help..
Old May 7, 2006 | 06:23 PM
italiaCLs's Avatar
boost is still at 4.5 max. I dont know what it is. any other suggestions?
Old May 7, 2006 | 07:16 PM
italiaCLs's Avatar
Old May 7, 2006 | 07:38 PM
sgmotoring's Avatar
Bleed Honda Blue
Do you have a high boost comptech pulley on the alternator already? If not I got SC side pulley for sale. ;D
Old May 7, 2006 | 09:56 PM
italiaCLs's Avatar
Yes i already have the high boost pulley. what pulley do you have?
Old May 8, 2006 | 10:00 AM
italiaCLs's Avatar
I am interested in a higher boost pulley. What are you sellihg it for? I know i have to intercool it and E-manege it in order to retard the pinging timing ETC..... you wouldnt happen to know what type or size intercooler (front mount) I can use?
Thank you
Old May 8, 2006 | 11:22 AM
Jonesi's Avatar
Old May 8, 2006 | 11:31 AM
italiaCLs's Avatar
Originally Posted by Jonesi
Already sent the PM but he hasnt sent one back... so im asking who ever i can.
Old May 8, 2006 | 12:20 PM
All Mine's Avatar
I'm a Vagiterian.
How do you FMIC one of these superchargers?
Old May 8, 2006 | 01:33 PM
italiaCLs's Avatar
The plumbing would be very stange but i think it can be done. It is deffinetly a custom job. the difficult part is that the intake runs where the piping for the IC would go....... im just trying to gather some info/data on how difficult this job will be..... i hope i can do it
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
