Problem with '03 Tail Lights
Old May 3, 2002 | 11:21 PM
silverstreak01's Avatar
Now i dont know if i did something wrong, but it seems as if i need more than two harnesses for my new tail lights. because i had to tape down two bulbs on each side. the turn signal on both sides and the brake light directly beneath both turn signals. Is this normal or did i simply just not put in the bulbs correctly? what the hell is goin on? HELP!!!!
Old May 3, 2002 | 11:26 PM
ReflexRacing_com's Avatar
URL Not Found!
Hey yo, where did you get your 03 Taillights? How much? Is the harness problem the only trouble your having?? Thanks.
Old May 3, 2002 | 11:39 PM
nate'sCLS's Avatar
I ordered them through http://www.autocarparts.com/ .
Old May 3, 2002 | 11:48 PM
nate'sCLS's Avatar
Re: Problem with '03 Tail Lights
If it is simply putting the bulbs in than I KNOW that works because I have tested the fit of my harness/bulb setup already. Refer to my thread at... http://www.acura-cl.com/forums/showt...threadid=68454
Old May 5, 2002 | 11:08 AM
bump ^
Old May 5, 2002 | 12:07 PM
nate'sCLS's Avatar
I just noticed the problem as I am installing the lamps right now.
The problem (minor one) is that the bulb below the turn signal (outer tail/brake light bulb) is a tight fit in the new housing. No biggie. After almost squeezing all of the blood out of my fingers trying to turn the bulb into that socket, I decided to stop being an idiot and turn it in with a wench... but don't squeeze the too much while doing this or you'll damage it
Old May 5, 2002 | 01:39 PM
MYtypeS02's Avatar
wat up es
You put em in wrong, mine fit PERFECTLY, the only issue was the turn signal, until I got the right harness...try it again silverstreak, you are probably not aligning and turning the sockets in right
Old May 5, 2002 | 04:28 PM
so the brake lights at the bottom are supposed to all fit fine?? and just the turn signals are supposed to need a new harness??
Old May 5, 2002 | 04:34 PM
MYtypeS02's Avatar
wat up es
Like I said, you did something wrong...THEY ALL FIT PERFECTLY, after you get the signal light sockets....if worse comes to worse, go to your dealership and have them turn the lights in for you....of course you'll look like an idiot, but at least you wont be freaking out anymore.
Old May 5, 2002 | 05:01 PM
nate'sCLS's Avatar
This is correct... just turn them with a wench using slight pressure
Old May 5, 2002 | 05:27 PM
MYtypeS02's Avatar
wat up es
good idea using plyers..it was a bitch using my hands, but it's easier that way if you're putting them on if the taillights are already on
Old May 5, 2002 | 05:37 PM
nate'sCLS's Avatar
Pliers… right that’s what those turny-thingy’s are!
Old May 5, 2002 | 05:44 PM
MYtypeS02's Avatar
wat up es
I meant "players" Tru playa's install there sockets without any kind of tools....
rockyboy
Aug 4, 2024 10:35 AM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
brjones9
Sep 3, 2015 07:30 PM
