Prepping before Installing Supercharger?
Old Aug 29, 2006 | 10:03 PM
JBlueCLS6's Avatar
Need to know any misc. parts I should look into before slapping on the charger.... I know I should definetly get a Pillar pod & Gauges as well as probably get some colder plugs (IK22?)... Is Porting the TB and IM really going to show a significant gain or is it not worth the small gains I'll get...
BTW I'll probably be running the 5 lb pulley & will get it tuned probably at Turbo Trix which is 3 blocks away from me or if you guys can recommend elsewhere I'll take that into consideration...
Any help would be appreciated. My current mods are in the sig minus the charger which has not been installed.
Old Aug 29, 2006 | 10:07 PM
allmotor_2000's Avatar
Colder Plugs
Mugen T-State and Switch
Don't waste your time on the stock intake unless you are making drastic mods
Get a wideband O2
Get a OBD-II scanner
If you increase boost, get a knock-sensor
Are you running the E-manage?
Old Aug 29, 2006 | 10:11 PM
JBlueCLS6's Avatar
got the Mugen mods
Are the IK22s needed or will the IK20s be fine on 5 lbs.
Alright I'll scrape the IM what about the TB?
I'll get the Wideband and I'm not certain if it comes with E-Manage... I'm buying the kit of another member... I'll have to touch base with him... do you know what ECU management comes with the kit usually?
Old Aug 29, 2006 | 10:18 PM
JBlueCLS6's Avatar
& Brett I see you lurking this thread so get your tools ready again =P
Old Aug 29, 2006 | 11:20 PM
Allout's Avatar
Blown is Best
Get the IK22's. There are two reasons.
1) They are a colder plug.
2) IK22's come gapped at .032". Both IK16's and IK20's are gapped at .044". FI mixtures are harder to fire through so the .032" gap helps assure a clean fire.
Old Aug 29, 2006 | 11:37 PM
Allout's Avatar
Blown is Best
Are you adding a fuel pressure gauge inside? If not, you may want to consider adding a fuel pressure gauge under your hood. I just ordered one of these and will be adding:
BoricuaTL
Apr 8, 2016 01:08 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
obert
Nov 7, 2015 07:32 PM
TxRzrBk
Sep 17, 2015 01:07 PM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
