Power Steering pump bearings shot what to do?
When i had my option pulley installed I had to take it to a local shop because I couldn't get the bolt off. turns out he made the power steering belt too tight and now the bearings are shot. Now the question is what should I do. Go after the shop? buy a new one or fix the existing one?
You can buy new bearings and seals for around 20 bucks. Throw it on your work bench and replace them. Its easy.
it bounces around in there quite a bit. If your worried take some of the fluid out (keep it above the low level though)
Blown is Best
It's usually a sign of a bad pump or a bad rack. By what you're describing, it's probably only your bad pump.
lowrd on tein CS biatch
a whining pump is usually due to low fluid.
My car made that noise badly before I bought it and they topped the fluid up and works perfectly..
NOTE*
When i did the underdrive pulley on a dry steer (car not moving) and u crank the wheel you can hear the pwr steering wine a lil since it is UNDERPOWERED.
I am getting overdrive pulleys to fix this eventually
but just to make sure that isn't the problem, think about it ;-)
NOTE*
i wouldnt if they arent bad.
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
