possible exhaust leak(maybe header flex joint)
Old Jan 22, 2005 | 04:59 PM
typeR's Avatar
i have comptech headers and bad motor mount ..front for sure maybe rear too...anyway my car's starting to sound like a ricer mobile...raspy escpecially in 1st low rpms...when i get above 5K sounds normal...i poked under the car alittle...sounds like the area near the cat...but a friend said he damaged a flex joint on his header from a bad motor mount.anyone ever experienced anything like this...any checks i can perform ,to determine exactlt where the sound is coming from
Old Jan 22, 2005 | 09:52 PM
typeR's Avatar
no help eh?
Old Jan 23, 2005 | 08:30 PM
typeR's Avatar
Old Jan 23, 2005 | 09:14 PM
allmotor_2000's Avatar
The motor must have moved a LOT to damage the flex joint. That is there to... as the name says.. 'flex'! Check if one of the runners has a crack in it.
Old Jan 24, 2005 | 09:13 AM
typeR's Avatar
can i do this with out removing the headers? like is there a way to poor soapy watter or some thing like that?
Old Jan 24, 2005 | 01:28 PM
Excelerate's Avatar
Former Sponsor
You do not have to remove the headers to do this. If you're talking about the flex pipe it is near the oxygen sensor. Just jack the car up or put it up on a lift. If there is a leak yes you can put soapy water on the flex pipe to see if it will bubble up b/c air is leaking out of the header and into the bubble. The only problem I would see is that the exhaust is so hot you would burn the water and bubbles before you could see anything. If there is a leak you will hear it or see it. There will be fumes and black liquid coming out of the leak. If you listen closely you will hear it too. Obviously you will have to have the car on to notice this while it is jacked up.
Josh
Excelerate LLC
Old Jan 24, 2005 | 02:28 PM
Shawn S's Avatar
I’ve heard that if you go to one of those muffler shop type places they have a “sniffer tool” that they can point around looking for leaks.
It senses carbon monoxide.
Shouldn’t be too much just for them to put it up on the lift and check.
Doesn’t mean you have to pay them to FIX the problem.
Old Jan 24, 2005 | 02:36 PM
Excelerate's Avatar
Former Sponsor
Nice Shawn, another Eagles fan. We're going to the Super Bowl. It's going to be a really good game against the Pats. We got T.O. back though so hopefully he'll explode for some big yardage along with Westbrook.
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
