Popped my clutch and Malfunction Indicator Light turns on. . .
6 Forward 1 Back
Could these be in any way related? I popped my clutch and stalled in a drive through. After I started it back up the light lit up. I do have the Comptech Icebox and thought maybe it is causing this by coincidence.
Originally posted by Zapata
how high did you pop it from?
6 Forward 1 Back
I did double check the gas cap as the owners manual says for this Malfunction light.
I guess I'm just worried that Acura won't honor the warranty if they see my Icebox. I only have 10,700 miles.
Cost Drivers!!!!
Originally posted by greenmonster
I've seen mine come on briefly when I dropped the clutch from about 2500 rpm (can you say wheelhop), but it only stayed on for about 30 seconds and then reset.
I've seen it as well when i get bad wheel hop.
6 Forward 1 Back
Are you refering to the CEL light?
Cost Drivers!!!!
Originally posted by Speed_Racer
Not sure what the CEL light it, but the manual calls this light the Malfunction Indicator Light. It looks like a engine icon. The manual keeps saying it was to do with excessive emissions.
hmmmm it's on all the time?? It's thrown a code....might want to take it to AutoZone so they can run a check? I remember Jens saying that the engine/ecu doesn't like very low RPMs?
6 Forward 1 Back
Thanks guys. I'll have it checked.
Spectacular Aroma About
Originally posted by allmotor_2000
Check the code.... if it *blinked*.... its the front motor-mount dampener, I believe. This car doesn't like the motor rocking!
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
