Polyurethane Motor Mounts Excellent MoD!
anyone who is having second thoughts about attempting to fill their mounts w/ poly should not think twice.
i was at a light next to a friend in a maxima with my buddy in the passenger seat. i turn off vsa and floor the gas (no brake torque), and the car slides through 1st gear to 40 mph like i was on a sheet of ice. no hopping at all. it probably would have slid through 2nd but i didn't want to find out.
wow, i never saw a FWD slide thru a gear like that with 0 hop. its a cheap and fairly easy mod. i noticed the poly squishing out of the sides, so i guess i'm going to have to try that engine damper too. these mounts just arent strong enough.
I'm here in spirit...
haha, i'm saying the mounts themselves arent strong at all, but with polyurethane are MUCH Better. from a visual standpoint it looks like they need some more assistance, but at the moment i got no hop at all, so i guess i can't complain.
i'm sure it would be improvement for ANYONE even stockers. bc i know even before my 3.5 i still hopped like crazy once and awhile if i got on it too hard.
they make different strength polyurethanes. one option is to try to source out something stronger. there is a very light vibration felt at idle while in gear, with the a/c off i can bearly feel it. i think for someone with less mods, wouldn't even notice the vibrations. i think the engine damper would seal the deal.
the front and side would be relatively easy, if you have some tools and jacks, i think anyone can do it, the rear looks harder, but again, if you have jacks you can drop it from the bottom rather than trying to pull it from the top.
traction... i dont know, the car just feels planted all the time during accleration. much less 'liftoff' feeling than before.
Originally Posted by fuzzy02CLS
I never had a real problem with hop, or traction in normal or even spirited driving. Except at the track. The hop can be corrected on the 6mt with throttle & clutch feathering. Something you can't do with an auto.
Fuzzy... I agree totally. I used to have stock shocks, Toyo TPTs and lowered w/o camber correction and my traction and wheel hop problems were terrible. I put in the Ingalls kit first and noticed a big improvement... then moved to the AVS 100 tires and they stuck like glue. I fiddled a lot with the Tokico's to find the right balance of performance and comfort and settled on 4 back, 3 front. Most recently I installed the damper... and I can't believe the difference it makes.
Tires and suspension are huge factors in actually translating engine power to forward motion
Lead Footed
Thanks for the feedback.
I think I saw sometime back someone do this and had similar results. I think it's time to do mine as it wheel hops like an SOB when I'm racing it.
Ruf
Ruf
