Polished intake manifold...
Old Aug 20, 2003 | 06:54 PM
Hobes's Avatar
My tuner has an extra intake manifold and is polishing the ports for me...anybody else have this done?
I am also looking into getting a chip from Japan...
Old Aug 21, 2003 | 12:58 AM
bullaculla's Avatar
someone had it done with unfavorable results.
BTW, i'm glad you found the Car Talk section.
Old Aug 21, 2003 | 03:46 AM
Hobes's Avatar
hmm....do you know who had it?
Old Aug 21, 2003 | 05:07 AM
scalbert's Avatar
I did it last fall. The results were not unfavorable; just indifferent.
Part 1
Part 2
Part 3
Old Aug 21, 2003 | 10:10 AM
Hobes's Avatar
scalbert...did you geta chance to dyno your car before and after?
Old Aug 21, 2003 | 10:50 AM
Mike's Avatar
I was the 1st one to do it on this board. :P gains were pretty minimal unless you're going the FI route.
Old Aug 21, 2003 | 11:10 AM
scalbert's Avatar
First off, yes, Mike was the first although he sent his off to be extrude honed. Read, Lazy... :P
As for before and after dyno, yes and no. I also had added the Mugen T-Stat and Fan switch. Other dynos showed that by dropping the engine temps from 200+ to the 180 F range gave about 5 - 7 lb/ft more torque. So the below really shows those gains and nothing from the polishing.
However, I should note, on the second dyno I was running a different intake which didn't amount to much over stock without the resonator. On the first dyno I was running an AEM intake.
Old Aug 21, 2003 | 11:33 AM
scalbert's Avatar
As a side note on my above dyno; notice how the dips and rises don't follow at the same RPM. Both the IMRC opening and VTEC change over has to occur at the same RPM but they are offset. So I wonder if the dyno was a bit off on its mag pick up.
Anyway, I did a quick correction and shifted the blue line to have the transition points match in RPM; plus 200 RPM. I then recalculated the WHP measurement based on the new RPM and it came out to 254.4 WHP.
So maybe there was more benefit than originally thought.
Old Aug 21, 2003 | 12:31 PM
mattg's Avatar
Old Aug 21, 2003 | 12:45 PM
johntypes's Avatar
dont do it i lost 15hp 17# of torque
pre dyno dynoed after same dyno
Old Aug 21, 2003 | 12:56 PM
mattg's Avatar
not from just the intake. you did your heads and everything, right john?
Old Aug 21, 2003 | 01:38 PM
sonor kid's Avatar
One who Laps
There are still some questions regarding how the shop did John's head. They say they didn't take that much off but his dyno numbers went down.
Be careful.
Old Aug 21, 2003 | 09:10 PM
allmotor_2000's Avatar
I have a ported and extrude-honed manifold... seemed to help.. .no dyno yet though!
Old Aug 21, 2003 | 09:47 PM
Mike's Avatar
Oh you brute!
I just wanted it done right...not by some hack from some where in georgia!
Old Aug 21, 2003 | 09:55 PM
KavexTrax's Avatar
yea umm Mike takes his polishing quite seriously.
Old Aug 21, 2003 | 09:59 PM
Mike's Avatar
shaddup bean pole!
Old Aug 21, 2003 | 10:43 PM
bullaculla's Avatar
This is the one I was talking about Scalbert.
not you
Old Aug 22, 2003 | 05:03 AM
scalbert's Avatar
Originally posted by Mike
Oh you brute!
It is actually southern ingenuity, or maybe it is stupidity, I can't remember which...
Old Aug 22, 2003 | 11:49 AM
Caddy©'s Avatar
Yea
Just a bunch of InBREEDS Down Here....
So....don't come down Mess with Our "Branchless Tree"
Old Aug 22, 2003 | 12:41 PM
CLpower's Avatar
teh Senior Instigator
Re: Polished intake manifold...
there is no chip from japan, don't do it, you will be getting ripped off
Old Aug 22, 2003 | 12:42 PM
CLpower's Avatar
Oh you brute!
and they did a great job the first few times around :P
Old Oct 18, 2003 | 01:35 AM
Daniel M CL/TL's Avatar
A-CL Member
Port n polish
SO, does anyone know the truth - does p/p do anthing for our engines? Has anyone tried it with s/c yet?
Old Oct 18, 2003 | 03:15 AM
EricL's Avatar
Re: Port n polish
If you are not going with a 6-speed and S/C, you might want to spend you money some where else... (my $0.02)
Count-up the positive vs. negative responses above.
There is always going to be a possibility that it would "help" with a particular configuration (3.5Liter with some other upper end mods [cams, valves, porting, higher rev limit via new ECU]) or S/C combo mentioned above.
The problem with the "truth" is: the "tested" configurations are all different.
Sometimes a little roughness can actually help keep the air velocity up in the intake runners and allow for better cylinder filling.
YMMV
Old Oct 18, 2003 | 05:58 AM
johntypes's Avatar
I did heads intake and vavle',s what a mistake that was .
Old Oct 18, 2003 | 10:22 AM
If its done properlyly, it will give you gains. However, that mod has to be accompanied by other mods. Take a situation where head can flow at say.. rate X cfm, but the TB only allows 1.1X cfm. Well, if you port the heads to flow 1.3X cfm, it won't do you any good!
Also... the amount, angle(s), countours etc. of the port make a big difference on how air fills up the combustion chamber and how exhaust leaves it. Sometimes you have to alter intake cam timing to accomodate the difference in flow.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
