Polarg M-6 install instructions..
I have talk to a lot of people that say they broke there bulbs trying to install there M-6 Polargs. Here is what you do. Just twist the bulb while you push it though. It will go right though. Not sure why this works but it does every time.
Mustang Killa
Mustang Killa
Well I have a easier way.... Take the Fogs out, then you will have all the access to the openings... Taking out the fogs are SUPER easy, just loose the screw on the side of the fogs, and yank it out... it's that simple.... took me 1mins to take them out.... Once the lights are out, put the bulbs in the socket first then slowly put them in straight, then you will have slim chance to break them due to going in sideway in a small tight space..... This tight space only happen on my passanger side fogs, the driver side fogs seem to be bigger and i helped several CL guys, all the same.... Driver side hole is larger than passanger.... Hope this help!
Edward
99TL, 01 CLP with stuff.
Houston(Sugarland),TX
Edward
<font face="Verdana, Arial" size="2">Originally posted by laser1180:
</font>
</font>
Once you have the lights out then you can follow my instructions. Or you can save yourself 15 - 20 min and just stick your hand up there. People that have broken there lights know what I am trying to say.
Mustang Killa
cycdaniel
Dec 17, 2019 10:58 AM
pistacio
Sep 26, 2015 09:45 AM
