Please HELPP-How to take out Head light
Old Oct 16, 2006 | 02:16 PM
CL-S 6MT's Avatar
B A N N E D
Hey guys my right Hid bulb blew out, please let me know on how to 5remove the headlights, plastic black trim is off
Old Oct 16, 2006 | 02:20 PM
03silvertypeS's Avatar
you looking for headlight assembly removal or bulb removal?
Old Oct 16, 2006 | 02:23 PM
CL-S 6MT's Avatar
B A N N E D
Originally Posted by 03silvertypeS
headlight or bulb removal?
well i need to replace the hid, on the side where there is no battery
Old Oct 16, 2006 | 02:24 PM
the hid unit or just the D2R bulb?
Old Oct 16, 2006 | 02:27 PM
CL-S 6MT's Avatar
B A N N E D
just the bulb
Old Oct 16, 2006 | 02:30 PM
in order to replace the HID unit, disconnect the battery, then you'll have to remove the bumper (use the search function for this, there's a bunch of threads and DIYs), then disconnect and remove the headlight assembly. There's 2 mounting bolts on top and 3 underneath.
After that, you'll need to remove the bulb socket from the HID bulb, remove the 3 mounting screws and the HID unit. Then install new one in reverse order of removal
For just the bulb, you'll need to take off the round cover on the back of the headlight assembly (remove the Torx bolt w/ tamper-proof torx T25 bit), inside you'll see the bulb, it's just a matter of disconnecting it, pulling out the retaining spring and installing the new one (make sure not to touch the glass of the bulbs).
Old Oct 16, 2006 | 02:36 PM
CL-S 6MT's Avatar
B A N N E D
Yeah i noticed the Torx, imma run to the store a purchase one as i dont have a 25, thanks alot for your help.
Old Oct 16, 2006 | 02:43 PM
you're welcome, it's not too bad of a job, i'm sure you'll be fine
Old Oct 16, 2006 | 05:43 PM
Landocommando12's Avatar
Dont know if it's the same thing or not, but when I did mine, it was a torx t-20.
Old Oct 20, 2006 | 01:36 PM
CL-S 6MT's Avatar
B A N N E D
Ok i just got around to changing it, i bought the T-25 but it does not fit, on the headlight it self where the torx tamper proof bolt is a little nipple in the middle of it, is it me or T-25 dosent work??
Old Oct 20, 2006 | 01:42 PM
superfob's Avatar
You need a security torx. Its different from a regular torx. Some people use a tiny flathead screwdriver to take out the screw instead of buying a security torx bit..
Old Oct 20, 2006 | 04:47 PM
Is the one you got too big? Mine was a torx T-20 not T-25.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
PortlandRL
Sep 14, 2015 12:01 PM
Ny1718
Sep 11, 2015 09:21 AM
